I Static rotational friction: does diameter matter?
The discussion centers on whether the diameter of a washer affects static friction in a bolted joint. One viewpoint suggests that friction is independent of surface area, implying diameter does not matter, while another argues that a larger diameter increases the moment due to friction acting further from the axis of rotation. The resolution lies in distinguishing between linear slip force and torque for tightening; the former is unaffected by diameter, while the latter is influenced by it. To analyze this, one must determine if the bolt head or washer is slipping and calculate torque based on the average diameter of the slipping surfaces. This topic is typically covered in machine design literature, particularly in sections on bolted joints.
ShearStress
Imagine a bolted joint with a washer between the bolt and the surface.
Assuming the washer is always covered by the bolt head so it's getting a consistent load, does the washer's diameter impact the static friction being imparted on the surface?
I see two conflicting ways of viewing this:
1.) Friction doesn't care about surface area, so no the washer diameter doesn't matter (perhaps this is more relevant for linear friction, not rotational?)
2.) The larger the washer is, the higher the moment is since the friction is acting further from the axis of rotation
What's the answer and how can this solution be expressed mathematically?
I don't see a conflict, the friction force stays the same but the moment is proportional to the diameter (assuming the normal force is equally distributed along the washer's diameter, which is not certain).
Your question is unclear:
1) If you are asking about the force to make the joint slip linearly, then your statement #1 is correct.
2) If you are asking about the torque to tighten the bolt, then your statement #2 is correct. The procedure is:
A) Determine if the bolt head is slipping on the washer or the washer is slipping on the joint.
B) Calculate the torque using the average diameter of the slipping surfaces, assuming the compressive stress is evenly distributed.
A quick search for bolt torque calculations did not find this, but it is in any book on machine design. It's in the chapter on bolted joints.
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
