Static vs Kinetic Friction on an Unbanked Ramp
The discussion clarifies the distinction between static and kinetic friction in the context of an unbanked ramp. Static friction applies when there is no relative motion between surfaces, such as when a wheel rolls without skidding, while kinetic friction occurs during sliding motion. For a wheel in motion, static friction provides the necessary centripetal force to maintain circular motion without slipping. The tangential component of static friction ensures rolling without slipping, which is crucial for maintaining maximum speed. Understanding this difference is essential for correctly applying the principles of friction in physics problems.
mancity
A car with a mass of 1000 kg is moving on an un-banked ramp with a radius of 100 m. What is the maximum speed the car can move without skidding if the coefficients of static and kinetic friction are 0.80 and 0.60 respectively?
mgμ=mv^2/r
I used kinetic friction and did mgμ_k=mv^2/r. However, the solution is mgμ_s=mv^2/r. I am confused on why we consider static friction and not kinetic friction, thanks!
It is a common misunderstanding.
Friction is about relative motion of surfaces in contact. Kinetic friction occurs when there is such relative motion; static occurs when there is no such relative motion, only the potential for it.
If a wheel is not skidding ("rolling contact") then there is no relative motion. The part of the wheel touching a road has, instantaneously, zero velocity.
Likes mancity and Tom.G
Here the friction has double role. Besides enabling the rolling without slipping, which applies even when the car moves along a straight road, the friction provides the centripetal force for the circular motion. "Skidding" here refers to the case when the friction is not enough to provide the centripetal force for the car to move in a circle of the given radius with the given velocity. In this case the car moves outwards from the center. You are looking for the situation when this does not happen and the car does not move along the radial direction and the component of the friction acting along the radial direction provides the centripetal force. No motion along the radial direction means that the radial component of friction is static.
There is a tangential component of friction that ensures rolling without slipping. This is also static, as described by @haruspex.
Only if there is tangential acceleration. This is important since any tangential frictional force contributes to the total frictional force, thereby "using up" some of the available ##\mu_sN## and reducing the max speed.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
