Statically indeterminate systems
In summary, the principle of virtual work can be used to solve approximately the statically indeterminate systems, also known as the 'unit load' method. This method involves removing extra supports and analyzing the beam as a determinate system, then replacing the supports one by one and solving for the unknown reactions and moments. This method is commonly used in the analysis of indeterminate beams and trusses.
reterty
29
I am interested in the following question: whether we can use the principle of virtual work to solve approximately (in the limit of small deformations) the statically indeterminate systems or this principle is ultimately equivalent to the the system of the independent equilibrium equations?
Yes this method is often used in the analysis of indeterminate beams and trusses. Often called the ‘unit load’ method, and considering a beam say supported on multiple pinned supports, the extra supports are removed and the beam analyzed as a determinate system with the equilibrium equations. Then the supports are one by one replaced with a unit load multiplied by the unknown reaction load, and solved again as a determinate beam . Summing the deflections of each result equal to zero at the supports, the beam can then be solved for the unknown reactions and moments, etc.
Related to Statically indeterminate systems
1. What is a statically indeterminate system?
A statically indeterminate system is a type of structural system in which the number of unknown reactions or internal forces is greater than the number of available equations of equilibrium. This means that the system cannot be solved using traditional methods of statics.
2. How do you determine the degree of indeterminacy in a system?
The degree of indeterminacy in a system can be determined by counting the number of unknown reactions or internal forces and subtracting the number of available equations of equilibrium. The resulting number is the degree of indeterminacy.
3. What are some common methods for analyzing statically indeterminate systems?
Some common methods for analyzing statically indeterminate systems include the slope-deflection method, the moment distribution method, and the force method. These methods involve solving a series of simultaneous equations to determine the unknown reactions and internal forces in the system.
4. What are some advantages of using statically indeterminate systems?
Statically indeterminate systems offer several advantages over statically determinate systems. They can be more efficient in terms of material usage, as they can distribute loads more evenly and reduce the size of individual members. They also have a higher load-carrying capacity and can be more resistant to external forces such as wind or earthquakes.
5. How do you handle thermal expansion in statically indeterminate systems?
Thermal expansion can cause significant stresses in statically indeterminate systems. To handle this, engineers often introduce additional supports or use expansion joints to allow the structure to expand and contract without causing damage. Another approach is to design the structure with materials that have a low coefficient of thermal expansion.
  • Classical Physics
  • Classical Physics
  • Classical Physics
