Statics, compute force in member of a frame
In summary, it is possible to use the method of sections to solve for the force in member AB in this frame problem. However, it is important to carefully consider the signs and directions of the external forces when setting up the moment equations. The correct answer is 3.78 KN.
jonjacson
447
38
Statics, compute force in member of a frame [SOLVED]
Hi guys, I opened this thread but then I saw the mistake and I tried to delete it but I don´t know how, I´m sorry.
I´ll show the problem using a picture:
Sum forces = 0
Sum moments = 0
M = r x f
Well my idea is using the method of sections, I´ll cut the bars AB and CD at the middle point and I´ll have two systems the one AEC and the bars AB, CD until their middle points and the system BDF and the bars AB, CD until their middle points too.
Once I have those two systems I can apply the moment equation around E and F, since there are only two external unknown forces to those systems, and they are the forces AB, CD for both systems and the 10 kn for the BDF system, I´ll have two equations and two unkowns, where I´ll be able to get AB.
The problem is that I get an answer of 5,2 KN for AB and the book says the result is 3,78KN.
So I´ll show the calculations that maybe are wrong.
I´d like to comment the fact that there are two black lines between CB and AD but I think they are not bars, since they are not connected to the points A,B,C,D I´m assuming those lines are there to show the meaning of the distances between those points. If I´m wrong all my calculations won´t correspond to the problem and obviously that´s the reason I´m getting a wrong result.
I think that the four angles a,b,c,d that I show on the right image are the same.
To calculate the angle d for example, I´ll use triangle DUC on the right image. Since the distance AD is 5, and the structure is symmetric there must be the same distance between AU and VD, but we know that from C to B there are 2 meters so the distance VD= AU = 3/2= 1,5 meters.
Once I know that, getting the angle is easy, using the triangle DUC for example:
angle d= arctg(2/2+1.5)= 29.74 º
Now let´s calculate the moments around point E:
In this case the external forces acting at A and C are shown with red arrows, assuming that AB is a compression force and CD is a tension force, at this point I´m not sure about that but I know that they should be opposite since if they were both tension or compression forces system ACE should rotate around E.
Me= Rec x CD + Rea x AB= (3,4) x (CD cosθ, CD sinθ) + (1.5, 6) x (-AB cosθ, AB sinθ)=
3 CD sinθ - 4 CD cosθ +1.5 AB sinθ + 6 AB cosθ = 0 ; equation 1
Now I calculate the moment around point F for the system on the right of the vertical red line:
Mf= Rfb x -AB + Rfd x 10kn + Rfd x -CD = (-3,4) x (AB cosθ, -AB sinθ ) + (-1.5, 6) x (10,0) + (-1.5, 6) x (- CD cosθ, -CD cosθ ) = 3 AB sinθ - 4 AB cos θ -60 + 1.5 CD sinθ +6 CD cos θ = 0;
equation 2
Now I use the value of the angle θ=29,74 and I get from equation 1:
AB (5.2 + 0.74) + CD (1.49 - 3.47) = 0 --------> CD = AB 2.25 ; MISTAKE WAS HERE
Equation 2 looks like this:
-60 + CD(0.74 + 5.2) + AB ( 1,49 - 3,47)= 0;
I substitute the value of CD at the second equation:
-60 + 5.94 ( 3 AB) -1,98 AB = 0;
Finally:
AB = 60/15.84 = 3.78 KN ;
Well I don´t know if I calculated incorrectly the angles, or if I simply made a mathematical mistake.
Hopefully you will see it, the correct result is 3,78 KN Compression.
edit:
I found the mistake CD = 3 AB not 2,25. But I don´t know how to delete the thread since it is clear now and I woulnd´t like to make you lose your time reading this.
ANybody knows if it´s possible to delete the thread? I can´t find a tool to do that.
Thanks
Hi there,
It seems like you have a good understanding of using the method of sections to solve this problem. However, I noticed a few small errors in your calculations that may have led to the incorrect answer.
First, in your moment equation around point E, you have a positive sign for the moment due to the external force at point A (Rea x AB). This should actually be a negative sign, since this force will create a clockwise moment around point E. Similarly, the moment due to the external force at point C (Rec x CD) should also have a negative sign.
Second, when you substitute the value of CD into your second moment equation, you have a positive sign for the moment due to the external force at point C (Rfc x -CD). This should also be a negative sign, since this force will create a clockwise moment around point F.
Finally, when you substitute the value of CD into your second moment equation, you have a positive sign for the moment due to the external force at point A (Rfa x -AB). This should be a negative sign, since this force will create a counterclockwise moment around point F.
Correcting these small errors should lead to the correct answer of 3.78 KN for the force in member AB.
As for deleting the thread, unfortunately I don't think that is possible. However, I would suggest editing the original post to include a note that the mistake has been corrected and the correct answer has been found. This way, anyone who comes across the thread in the future will know that the problem has been solved.
Related to Statics, compute force in member of a frame
1. How do you calculate the force in a member of a frame?
In order to calculate the force in a member of a frame, you need to use the principles of statics. This involves analyzing the external forces acting on the frame, such as gravity and applied loads, and determining the internal forces within the frame that are in equilibrium with these external forces. This can be done using equations such as the sum of forces and the sum of moments.
2. What is the difference between axial force and shear force?
Axial force is a type of internal force that acts along the length of a member, either in compression or tension. Shear force, on the other hand, is a type of internal force that acts perpendicular to the length of a member. In other words, axial force pushes or pulls on a member, while shear force tries to slide the member in two different directions.
3. How do you determine the direction of the internal forces in a frame?
The direction of the internal forces in a frame can be determined by using the right-hand rule. This involves placing your right hand on the member, with your fingers pointing in the direction of the external force acting on that member. Your thumb will then point in the direction of the internal force within the member.
4. What is the difference between a frame and a truss?
A frame is a type of structure that consists of multiple members connected together at their joints. It is capable of supporting both axial and shear forces. A truss, on the other hand, is a type of frame that is specifically designed to resist axial forces only. Trusses are typically used in bridges and roofs.
5. How do external loads affect the internal forces in a frame?
External loads, such as applied forces and moments, will cause changes in the internal forces within a frame. These changes can be calculated using the equations of statics, and the resulting internal forces will be in equilibrium with the external loads. This means that the frame will remain stable and not collapse under the applied loads.
