- #36
Sagittarius A-Star
- 966
Do you mean that Sommerfeld didn't consider the self-induced Hall effect?vanhees71 said:The only exception is Sommerfeld's Lectures of Theoretical Physics, vol. III, which I cited. What's now missing is the discussion of the Poynting vector, i.e., the energy transfer along the cable, which is interesting in its own right (and also discussed for the non-relativistic approximation by Sommerfeld).
I'm not sure why this is called "non-relativistic".
He assumed that there is no radial E-field in the wire volume, because the volume charge density in the wire is homogeneously zero.
If you calculate in Sommerfeld's book, §17, equation (9a), the ##\lim_{b \rightarrow \infty} ## of ##E_r## in the intermediate space ##a<r<b## of the coaxial cable, then you get ##E_r=0## and therefore no surface charge density on the inner wire.
Source:
https://archive.org/details/in.ernet.dli.2015.147970/page/n137/mode/2up
Calculation
I think this might be a good model for Purcell's infinite straight wire, when the outer return path is infinitely far away.
I can't find in your actual paper a proof for the following statement:
... in which reference frame the wire is uncharged. It is not the rest frame of the wire (i.e., the rest frame of the ions) but the restframe of the conduction electrons [Pet85].
In the AJP paper, which I linked in #18, a positive surface charge density compensates the negative volume charge density. Sommerfeld's assumption, that there is no radial E-field in the wire, is not fulfilled. But the positive surface charge density would compensate the ##E_r## outside of the surface to zero.
I see no indication in your paper (I don't have access to the full paper of Peters), what motivation the battery should have to provide extra electrons, if the wire is overall electrically neutral in it's rest frame.
