Undergrad Stationary Monopole exist at the Origin
  • Thread starter Thread starter Philosophaie
    Monopole Origin
A stationary monopole is theorized to exist at the origin, represented mathematically by the equations for magnetic and electric fields. The discussion highlights that both magnetic and electric current densities (J_m and J_e) are zero in a static case, suggesting no monopole presence. While the concept of magnetic monopoles could symmetrize Maxwell's equations, there is currently no experimental evidence supporting their existence. The conversation acknowledges the speculative nature of monopole behavior, emphasizing that discussions remain theoretical. Overall, the existence of stationary monopoles remains unproven and largely hypothetical.
Philosophaie
A stationary Monopole exist at the Origin.
1)##\vec{B} = \frac{g \hat r}{4 \pi r^2}##
2)##\vec{E} = \frac{e \hat r}{4 \pi \epsilon_0 r^2}##
3)## - \nabla \times \vec{E} = \frac{\partial \vec B}{c \partial t} + \frac{4 \pi}{c} \vec{J_m}##
4)##\nabla \times \vec{B} = \frac{\partial \vec E}{c \partial t} + \frac{4 \pi}{c} \vec{J_e}##
##- \nabla \times \vec{E} = 0##
##\frac{\partial B}{c \partial t} = 0##
therefore
##J_m = 0##
Similarly
##J_e = 0##
Is this correct?
There is no evidence for magnetic monopoles, so any discussion about how they would behave is speculation
Well, it's nevertheless interesting. Of course, in the static case you have ##\vec{J}_e=\vec{J}_m=0##.
My first-year intro physics textbook (Halliday & Resnick, Fundamentals of Physics, 2nd ed., early 1970s) noted briefly that Maxwell's equations could be made symmetric between E and B by introducing magnetic monopoles, in the form shown in post #1 (as well as in Wikipedia). It then quickly noted, of course, that no magnetic monopoles have ever been observed. And this is probably not the only way one could set up electromagnetism with monopoles, simply the most "obvious" way.
Likes Philosophaie and vanhees71
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
  • · Replies 29 ·
