Stationary temperature field inside a house
Your Name]In summary, the conversation discusses calculating the stationary temperature field inside a room with isolated walls and two windows that allow for convective heat exchange. The homework equations for this problem involve the diffusion equation and the Laplace equation, and the boundary conditions would depend on the specific dimensions and properties of the room and windows. One possible approach to solving this problem would involve setting up a system of equations and using numerical or analytical methods to find the temperature field. Other factors, such as air flow and insulation, may also affect the temperature.
ficku1
House: a room (see figure) has perfectly isolated walls, except the two windows
where a convective heat exchange takes place (with the same transfer coefficient).
Outside temperature in front of a sun-faced wall-sized panoramic window is T1,
while at the back it is T2.Calculate the stationary temperature field inside the
room. You can also play by adding an additional energy flux through the front
window due to a sunlight at an angle φ.
For this assignment we have to use the diffusion equation
dT/dt=D (d2T)/dx2
If we are calculating stationary temperature the equation is actually Lapace ΔT=0 .
I think it is not the same in the x and y direction because the windows aren't the same size and the sun is only shining in the room on one side. So we separate the variables T=X(x)Y(y) and we get
1/X * (d2X)/dx2=-1/Y * (d2Y)/dy2 =C
But i am not sure what the boundary conditions should be?
Thank you for your help.
  • room.pdf
Thank you for your question. The boundary conditions for this problem would depend on the specific dimensions and properties of the room and windows. However, in general, the boundary conditions for this problem would involve the temperature at the walls and windows, as well as the heat transfer coefficient and any additional energy flux from sunlight.
One possible approach to solving this problem would be to use the boundary conditions at the walls and windows to set up a system of equations, and then use numerical methods or analytical techniques to solve for the temperature field inside the room. It may also be helpful to consider any other factors that could affect the temperature, such as air flow or insulation.
I hope this helps. Good luck with your calculations!
Related to Stationary temperature field inside a house
1. What factors affect the stationary temperature field inside a house?
The stationary temperature field inside a house is affected by various factors such as the outdoor temperature, insulation of the house, HVAC system, and the location of windows and doors.
2. How does insulation impact the stationary temperature field inside a house?
Insulation plays a crucial role in maintaining a stationary temperature field inside a house. Good insulation helps to prevent heat loss and keeps the temperature consistent throughout the house.
3. Can the HVAC system affect the stationary temperature field inside a house?
Yes, the HVAC system can significantly impact the stationary temperature field inside a house. The system's efficiency, size, and maintenance affect how well the house is heated or cooled, ultimately impacting the stationary temperature field.
4. Is it normal for different rooms in a house to have different stationary temperature fields?
Yes, it is normal for different rooms in a house to have slightly different stationary temperature fields. This can be due to various factors such as the location of windows and doors, the number of people in the room, and the HVAC system's efficiency.
5. How can I improve the stationary temperature field inside my house?
To improve the stationary temperature field inside your house, you can consider adding more insulation, sealing any air leaks, and ensuring that your HVAC system is properly maintained. You can also use curtains or blinds to regulate the amount of sunlight entering the house and affect the temperature inside.
9K
  • Differential Equations
