- #36
FactChecker
2023 Award
- 8,862
- 4,299
Good question. There is a big difference because you are giving the null hypothesis every advantage. You start by picking one hypothesis as the null hypothesis, giving it all the benefit of the doubt by using its distribution and parameters and saying that you will only change that assumption if there is strong test indications (over 95%, 99%, etc.) that it might be wrong.gleem said:Is there any difference in assuming something is or isn't safe? If you compare it to a safe population the process is the same. in one case you look for evidence that it can be a member of the safe population and there is assumed to be safe and in the other you look for evidence that it is not a member of the safe population and therefore is assumed to be unsafe.
In the case of testing the safety and effectiveness of a drug, they should assume that it is not safe or not effective and run tests that would convince even a skeptical audience that it is safe and effective. The burden of proof must be on the drug company to prove its drug is probably (95%, 99%, etc.) safe and effective. Otherwise, many unsafe and/or ineffective drugs would pass a minimal test and be approved for public use.
