Statistical physics - does total energy matter, or only differences?
In statistical physics, the total energy in a two-level system can influence the partition function, which is crucial for calculating thermodynamic properties. Two situations with different energy references yield distinct partition functions, indicating that total energy does matter for energy-level dependent quantities like mean energy. The mean energy calculations show that while one expression approaches a specific value as temperature approaches zero, the other approaches zero, reflecting the importance of energy reference. However, energy-independent quantities, such as energy fluctuations and average magnetic moments, remain consistent across different energy references. This highlights that while total energy influences certain calculations, differences in energy are more significant for others.
laser1
Desc
Z
In statistical physics, in a two level system, I'll give an example to show what I am talking about:
situation 1) energy 0 and energy E
situation 2) energy E/2 and energy -E/2
Are these two situations equivalent? Computing the partition function for both of them it seems they are different, but I am not sure. Because from my experience when dealing with energies in mechanics only the energy difference is important. Cheers
Can you write the two expressions? Why do you think it matters?
The two expressions for ##Z##:
1) ##e^{-\beta \epsilon}+1##
2) ##2\cosh\left(\frac{\beta \epsilon}{2}\right)##
I think it matters because they are two different expressions!
Well the partition functions cannot be exactly the same because energies are slightly shifted so it matter for energy-level dependent quantities, for example if you calculate the mean energy ##\overline{E}=-\partial \ln Z/\partial \beta## you get:
  1. ##\epsilon/(e^{\beta \epsilon}+1)##
  2. ##\epsilon \tanh(\beta \epsilon/2)/2##
As ##\beta \to 0##, Eq.1 goes to ##\epsilon/2## and Eq.2 goes to ##0## (the average value) as you would expect because of the choice of energy reference. However if you calculate a quantity that does not depend on the energy reference, for example the energy fluctuations around the mean ##\Delta E^2=\overline {E^2}-\overline{E}^2=\partial^2 \ln Z/\partial \beta^2## you get
$$\Delta E^2=\frac{\epsilon^2 e^{\beta \epsilon}}{(e^{\beta \epsilon}+1)^2}$$
for both. You can try with other energy-independent quantities.
Likes vela and laser1
Here is another example, imagine that the higher energy state has a magnetic moment ##m## associated to it, and the lower energy state has a moment ##-m##. The average magnetic moment is
$$\overline{m}=m\frac{\exp(-\beta \epsilon)-1}{\exp(-\beta \epsilon)+1}=m\frac{\exp(-\beta \epsilon/2)-\exp(\beta \epsilon/2)}{\exp(-\beta \epsilon/2)+\exp(\beta \epsilon/2)}$$
which is the same value for both.
Another way to check all of this is to write a system with energies ##-E_0## and ##E-E_0##. If you calculate the mean energy it will depend on ##E_0##, but if you write the other two quantities above, ##E_0## will vanish.
You can see the shift a little more easily if you rewrite the first partition function ##Z_1## as
$$Z_1 = e^{\beta \epsilon}+1 = e^{\beta \epsilon/2}[\underbrace{2\cosh (\beta \epsilon/2)}_{Z_2}].$$ When you calculate the mean energy, the exponential factor contributes a shift of ##\epsilon/2## to the mean energy you get from the second partition function ##Z_2##.
Likes laser1 and pines-demon
