Statistical Physics - Equilibrium
In summary, the author claims that equilibrium is the most probable energy state, and that energy flow from one system to the other is not observable. If we are out of equilibrium, the probability for energy going from one system to the other is not the same as the reverse probability, and the system will approach equilibrium sooner or later. There are some unspecified assumptions in the text, but if we include the assumption of ergodicity, then the rest of the concepts in the text make sense.
SchroedingersLion
215
57
Good evening,
I have a question to a short introduction to statistical mechanics in a book about molecular dynamics simulation.
It introduces the fundamental assumption: Every microscopic state with a fix total energy E is equally probable.
I attached the section. I understand it all, except for the very last sentence.
Why does the author claim that, if we start at some random energy for E1, we will have energy exchange until eq. (2.1.3) holds? As he explained it, "equilibrium" is only the energy state with the largest number of corresponding micro configurations - and, since all of them are equally likely according to the assumption from the beginning, the equilibrium is the most probable energy state. But this does not explain why any other state would change towards equilibrium through energy exchange on its own.
The authors did say that their way of introducing statistical physics is somewhat dirty. Is there missing a point?
Regards,
SL
  • Dok123.pdf
There are a few unspecified assumptions in the text. The one that is important here is that the systems you are considering are big enough that fluctuations in energy will be too small to be measurable once equilibrium is reached, where the probability of energy going to from system 1 to system 2 will be equal to the reverse probability.
The two systems are always exchanging energy, but the number of microstates corresponding to the equilibrium condition is so huge that the flow energy from one system to the other is not observable anymore. The function Ω is so narrowly peaked that its width is not measurable.
Likes SchroedingersLion
Ok, to put it in my own words:
The systems are always exchanging energy. If we are out of equilibrium, the probability for energy going from one system to the other is not the same as the reverse probability, that's why we will approach the equilibrium energy distribution sooner or later.
But from the introduced terms in the extract, this is not really obvious, because there is not a single term that describes energy flow from system 1 to system 2.
From my point of view: Just because equilibrium has the greatest probability does not mean that any other state will reach equilibrium.
Greatest probability to me would just imply: If I prepared an ensemble of these systems in random micro configurations, out of all energy distributions, the equilibrium distribution is the most probable.
Only if I introduce the additive assumptions that the probability to transfer energy from one system to the other is only equal to the reverse probability in equilibrium, I find that the system will always equilibrium.
Well, on average every state will end up in thermal equilibrium. To understand this really, in my opinion you have to study non-equilibrium statistical physics, particularly the Boltzmann equation. The best introduction I know about this topic is Landau&Lifshitz vol. X (btw. also vol. V for equilibrium statistical physics is excellent).
Indeed, there are some other considerations here. That's another unwritten assumption: that the systems under consideration can reach equilibrium in a reasonable time. Some systems are metastable, but then again it is not the point of equilibrium thermodynamics to study such systems. For instance, the Sun is not in equilibrium with the universe, but there are some other ways to model it thermodynamically.
I should probably add another unwritten assumption: ergodicity. In such cases, it is assumed that ensemble averages, like you are describing, are the same as time averages. That means that the system will explore enough microstates in a relative short amount of time such that it will explore macrostates of increasing probability as time goes by (again, this would not be the case for a metastable system).
Likes SchroedingersLion and vanhees71
Thank you guys!
Related to Statistical Physics - Equilibrium
1. What is statistical physics?
Statistical physics is a branch of physics that uses statistical methods and concepts to study the behavior and properties of large systems of particles, such as atoms and molecules. It provides a framework for understanding and predicting the macroscopic behavior of systems based on the microscopic behavior of their constituent particles.
2. What is equilibrium in statistical physics?
In statistical physics, equilibrium refers to a state in which a system has reached a balance and its macroscopic properties, such as temperature and pressure, remain constant over time. This state is characterized by a lack of any net flow of energy or matter within the system, and is described by statistical mechanics through the use of equilibrium statistical ensembles.
3. How is equilibrium achieved in a system?
Equilibrium in a system is achieved when the system reaches a state of maximum entropy, or disorder. This can happen through various processes, such as heat transfer, phase transitions, or chemical reactions. In statistical physics, equilibrium is described by the principle of maximum entropy, which states that a system will naturally evolve towards a state of maximum entropy.
4. What are the different types of equilibrium in statistical physics?
There are three main types of equilibrium in statistical physics: thermal equilibrium, mechanical equilibrium, and chemical equilibrium. Thermal equilibrium refers to a state where the temperature is constant throughout the system. Mechanical equilibrium is a state where the pressure is constant throughout the system. Chemical equilibrium is a state where the concentrations of different chemical species within the system remain constant over time.
5. How does statistical physics relate to thermodynamics?
Statistical physics is closely related to thermodynamics, as both fields deal with the behavior and properties of macroscopic systems. However, while thermodynamics focuses on the macroscopic properties of a system, statistical physics provides a microscopic understanding of these properties through the use of statistical methods and concepts. In other words, thermodynamics is an application of statistical physics to macroscopic systems.
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
