Statistical physics : Irreversibility
In summary, statistical physics is a branch of physics that studies the behavior of large systems of particles. One of its key concepts is irreversibility, which refers to the tendency of physical processes to move in only one direction, from a state of high organization to a state of disorder. This principle helps explain phenomena such as the increase of entropy in closed systems and the arrow of time. Statistical physics also plays a crucial role in understanding complex systems, such as weather patterns and biological processes. Overall, it provides a valuable framework for understanding the behavior of systems on a macroscopic scale.
dontknow
TL;DR Summary
The Entropy of an isolated always increases.
I was reading mehran kardar (books and lectures) it says the concept of irreversibility comes from an assumption (in which we increase the length scale by interaction disctance between two particles).
So My question is the concept of irreversibility is still valid in the case of 1 particle.
Let's take an example from Feynman 2nd volume; A hydrogen atom going from excited to ground state is more probable thing to happen than a de-excited electron get excited by a photon. His explanation is that for an excited state initially entropy is low because photon (in final state) is something that is wandering in different direction so there is an increase in entropy.
Coming back to question where does the explanation for irreversibility come for the case of 1 or few particle system.
dontknow said:
A hydrogen atom always goes from excited to ground state, not the other way.
Hmm, that doesn't seem right. A hydrogen atom clearly can go from the ground state to the excited state too.
Likes vanhees71
The single atom is interacting with many other things that are not explicitly mentioned, such as the quantum state of the electromagnetic field surrounding the atom. The background electromagnetic field can provide a thermal bath for the atom.
The background section (first paragraph) of https://arxiv.org/abs/1510.04745v1 has some related references.
Chapter 3 of https://www.uibk.ac.at/th-physik/cqed/theses/bachelorthesis_kruckenhauser_andreas.pdf models spontaneous emission by coupling the atom to the background electromagnetic field.
dontknow said:
Summary:: The Entropy of an isolated always increases.
Maybe, Feynman's reasoning can be easier understood when one conceptually explains “entropy” qualitatively in the following way:
The second law of thermodynamics says that energy of all kinds in our material world disperses or spreads out if it is not hindered from doing so. Entropy is the quantitative measure of that kind of spontaneous process: how much energy has ‘flowed’ from being localized to becoming more widely spread out (at a specific temperature). [Quotation marks by LJ]
Frank L. Lambert in “Entropy Is Simple — If We Avoid The Briar Patches!” (http://entropysimple.oxy.edu/content.htm#increase)
Thermodynamic processes entail spatial redistributions of internal energies, namely, the spatial spreading of energy. Thermal equilibrium is reached when energy has spread maximally; i.e., energy is distributed equitably and entropy is maximized.
Harvey S. Leff in “Removing the Mystery of Entropy and Thermodynamics – Part I” (Phys. Teach. 50, 28 (2012))
Feynman (in “Feynman lectures Vol. III”, Chapter 7.1) puts it in the following way:
Why does an atom radiate light? The answer has to do with entropy. When the energy is in the electromagnetic field, there are so many different ways it can be—so many different places where it can wander—that if we look for the equilibrium condition, we find that in the most probable situation the field is excited with a photon, and the atom is de-excited. It takes a very long time for the photon to come back and find that it can knock the atom back up again.
Likes atyy
The whole subject of thermodynamics including the 2nd law, is based on statistical mechanics. You can't apply statistics to 1 or 2 particles. You can't define temperature or entropy for 1 or 2 particles.
For example, what is the temperature of a free electron? There is no answer, the concept of temperature does not apply to a single particle.
Indeed, at the atomic level where we track every particle, almost all (not all but almost all) are time reversible.
Indeed, and in equilibrium the rate of excitation is the same as that of the relaxation.
The H theorem (increase of entropy) follows from the unitarity of the S matrix and Boltzmann's "molecular-chaos assumption" to truncate the BBGKY hierarchy in the usual way by approximating the two-particle phase-space distribution function with the product of the corresponding single-particle distribution functions.
Likes Dale
For sure?
What about the average over time (ergodicity)?
In statistical mechanics temperature is an average kinetic energy.
rentier said:
For sure?
Then you don't have a single particle, but an individual particle interacting with a reservoir.
Likes vanhees71
rentier said:
For sure?
Sure, you can define temperature for a single particle coupled to a heat bath. Look for Fokker-Planck and/or Langevin equation.
Likes rentier
What is an example for _not_ reversible? (in statistical mechanics, not quants)
Related to Statistical physics : Irreversibility
1. What is statistical physics?
Statistical physics is a branch of physics that uses statistical methods to study the behavior of large systems of particles. It aims to understand macroscopic properties of matter by analyzing the microscopic behavior of individual particles.
2. What is irreversibility in statistical physics?
Irreversibility is a concept in statistical physics that refers to the inability to reverse the direction of a physical process. This means that certain processes, such as diffusion or heat transfer, can only occur in one direction and cannot be reversed.
3. What causes irreversibility in physical processes?
Irreversibility in physical processes is caused by the increase in entropy, or disorder, that occurs in a system over time. As particles move and interact, they become increasingly disordered, making it impossible to reverse the process and return the system to its original state.
4. How is irreversibility related to the second law of thermodynamics?
The second law of thermodynamics states that the total entropy of a closed system will never decrease over time. This is closely related to the concept of irreversibility, as the increase in entropy is what causes physical processes to be irreversible.
5. Can irreversibility be observed in everyday life?
Yes, irreversibility can be observed in many everyday processes, such as the melting of ice cubes, the diffusion of perfume in a room, or the mixing of different colored liquids. These processes are all irreversible and are governed by the laws of statistical physics.
  • Classical Physics
  • Classical Physics
  • Quantum Physics
  • Classical Physics
