Statistics - Finding a relationship?
In summary, the relationships between the means of y and x are that the mean of y is equal to the constant a times the mean of x plus the constant b, and the relationships between the standard deviations of y and x is that the standard deviation of y is equal to the constant a times the standard deviation of x.
shamieh
539
let a and b be constants and let \(\displaystyle y_j = ax_j+b\) for \(\displaystyle j = 1,2...n\). What are the relationships between the means of y and x, and the standard deviations of y and x?
I'm not sure what they are wanting here?
Mathematics news on Phys.org
Let's look at the means first...we know:
\(\displaystyle \overline{y}=\frac{1}{n}\sum_{j=1}^n\left(y_j\right)\)
Can you use the definition of $y_j$ and the properties of sums to obtain a relationship between $\overline{y}$ and $\overline{y}$?
Once you have the above, then look at:
\(\displaystyle \sigma_y=\sqrt{\frac{\sum\limits_{j=1}^n\left(y_j-\overline{y}\right)^2}{n}}\)
Replace $y_j$ and $\overline{y}$ with the expressions in terms of $x_j$ and $\overline{x}$, and you should be able to establish a relationship between $\sigma_y$ and $\sigma_x$. :D
would it be that they are both squared?
I don't really understand. This is my first statistic class. is ybar supposed to be the symbol for the mean?
Sorry for multiple posts. I think I see it now. the deviation of the $i^{th}$ observation, $y_i$, from the sample mean $\overline{y}$ is the difference between them $y_i - \overline{y}$
Yes, the bar over a variable represents the mean.
This is what I was suggesting you do:
\(\displaystyle \overline{y}=\frac{1}{n}\sum_{j=1}^n\left(y_j\right)=\frac{1}{n}\sum_{j=1}^n\left(ax_j+b\right)=a\frac{1}{n}\sum_{j=1}^n\left(x_j\right)+\frac{1}{n}bn=a\overline{x}+b\)
Now for the deviation:
\(\displaystyle \sigma_y=\sqrt{\frac{\sum\limits_{j=1}^n\left(y_j-\overline{y}\right)^2}{n}}=\sqrt{\frac{\sum\limits_{j=1}^n\left(ax_j+b-a\overline{x}-b\right)^2}{n}}=a\sqrt{\frac{\sum\limits_{j=1}^n\left(x_j-\overline{x}\right)^2}{n}}=a\sigma_x\)
Both of these results should agree nicely with intuition too. :D
FAQ: Statistics - Finding a relationship?
Q1. What is the purpose of finding a relationship in statistics?
Finding a relationship in statistics helps us understand the connection or correlation between two variables. This allows us to make predictions and draw conclusions about the data.
Q2. How do you determine if there is a relationship between two variables?
To determine if there is a relationship between two variables, we can use statistical methods such as correlation analysis or regression analysis. These methods help us identify the strength and direction of the relationship.
Q3. What is the difference between correlation and causation?
Correlation is a statistical measure that shows the relationship between two variables, while causation is the act of one variable directly causing a change in another. Correlation does not imply causation, as there could be other factors at play.
Q4. How do outliers affect the relationship between two variables?
Outliers are data points that fall significantly outside the range of other data points. They can greatly affect the relationship between two variables, either by strengthening or weakening it. It is important to identify and handle outliers carefully in statistical analysis.
Q5. Can a relationship between two variables change over time?
Yes, a relationship between two variables can change over time. This is known as a dynamic relationship. Factors such as external influences, changing trends, or the introduction of new variables can impact the relationship between two variables.
