Statistics: Mean and Standard Deviation
That should give you the answer you need.In summary, the question asks for the standard deviation of the number of people favoring a police substation based on a survey where 80% of the community is in favor. The mean is not 15 as it is a binomial distribution with n=15. The standard deviation can be calculated using the formula \sqrt{npq}.
nessa
In a recent survey, 80% of the community favored building a police substation in their neighborhood. If 15 citizen are chosen, what is the standard deviation of the number favoring the substation?
I know that my mean is 15 and the probiblilty is 80 but how do I get the standard deviation.
The answer is 12.
Do NOT simply give out the answer. In fact, don't give the answer at all in the homework section! (Not even a wrong answer! The question was about the standard deviation, not the mean.)
(Editted by HallsofIvy)
You need to go back and read the basic definitions! The number of people surveyed is 15. That surely does not mean that they will expect all 15 to favor the substation! The expected value (mean) is not 15.
This is a binomial distribution with p= .8, q= 1- .8= .2, and n= 15. I'm sure you textbook tells you that the mean of a binomial distribution is np and the standard deviation is [itex]\sqrt{npq}[/itex].
Related to Statistics: Mean and Standard Deviation
1. What is the difference between mean and standard deviation?
Mean is a measure of central tendency that represents the average value of a dataset, while standard deviation measures the spread or variability of the data around the mean. In other words, mean tells us where the data is centered, while standard deviation tells us how far the data points are from the mean.
2. How do you calculate the mean and standard deviation?
To calculate the mean, add up all the values in the dataset and divide by the total number of values. For example, if we have the values 3, 5, and 7, the mean would be (3+5+7)/3 = 5. To calculate the standard deviation, first find the mean, then subtract the mean from each data point, square the differences, add them together, divide by the total number of values, and finally take the square root of the result. This may sound complicated, but it is easily done using a calculator or a spreadsheet program.
3. What is the purpose of using mean and standard deviation in statistics?
Mean and standard deviation are important descriptive statistics that help us understand the characteristics of a dataset. They provide information about the central tendency and variability of the data, which can be used to make comparisons between different groups or to identify outliers or unusual data points.
4. Can mean and standard deviation be used to make predictions about future data?
No, mean and standard deviation are not suitable for predicting future data. They are only descriptive statistics that summarize the characteristics of a given dataset. To make predictions, other statistical methods such as regression analysis or time series analysis should be used.
5. How does the sample size affect the mean and standard deviation?
The larger the sample size, the more reliable the mean and standard deviation will be. With a larger sample size, the mean and standard deviation will better represent the true characteristics of the population. As the sample size decreases, there is a greater chance of sampling error, which can lead to inaccurate mean and standard deviation values.
