MHB Statistics Normal Distribution
Eleanor scored 680 on the SAT math section, with a mean of 547 and a standard deviation of 85, resulting in a standardized score of 1.553 when calculated. Gerald scored 27 on the ACT, where the mean is 21.3 and the standard deviation is 3.4, yielding a standardized score of 1.676. Comparing their standardized scores indicates that Gerald performed better than Eleanor when assuming both tests measure the same ability. The discussion emphasizes the importance of standardized scores in evaluating performance across different assessments. Overall, Gerald's higher standardized score suggests he has the superior performance in this context.
Junior1
Eleanor scores 680 on the mathematics part of the SAT. The distribution of SAT math scores in recent years has been Normal with mean 547 and standard deviation 85.
Gerald takes the ACT Assessment mathematics test and scores 27. ACT math scores are Normally distributed with mean 21.3 and standard deviation 3.4.
What is Elanor's standardized score? ______ Round to 3 decimal places.
What is Gerald's standardized score?________ Round to 3 decimal places.
Assuming that both tests measure the same kind of ability, who has the higher score?
___Gerald.
___Elanor.
___They both did equally well.
Mathematics news on Phys.org
___Gerald.
___Elanor.
Hi Junior! Welcome to MHB! ;)
A standardized score is calculated by taking the score, subtract the mean, and divide by the standard deviation.
What would we get as standardized scores? (Wondering)
Equivalently, the 'standard score' is the number of standard deviations the score is above or below the mean. Eleanor scored 680 and the mean is 547 so she scored 680- 547= 133 above the mean. If the standard deviation is 85, how many "standard deviations" is that?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
