Statistics proof, identically distributed RVs and variance
In summary, the variance of the average for identically distributed, but not necessarily independent random variables with positive pairwise correlation ρ is ρσ^2 + (1-ρ)σ^2/B.
vj3336
Show that for identically distributed, but not necessarily independent random variables with positive pairwise correlation ρ, the variance of their average is ρσ^2 + (1-ρ)σ^2/B.
ρ - pairwise corellation
σ^2 - variance of each variable
B - number of samples
I'm totally stuck on this problem, I don't know where to start.
Can you give me some starting hint ?
I know that variance of the average for independent identically distributed random variables is σ^2/B
Let's do this for two samples to ease the notation. Do you know how to calculate:
[tex]Var(X+Y)[/tex]
I think I could, I would start with this :
Var(X+Y) = Var(X) + Var(Y) = E[(X-μx)^2] - E[(Y-μy)^2]
where μx is the mean of RV X, and μy the mean of RV Y
This is not true! You should have a formula in your course that calculates the variance of a sum...
right, so when X and Y are correlated
Var(X+Y) = Var(X) + Var(Y) + 2ρ*Sqrt(Var(X))*Sqrt(Var(Y))
where ρ is corelattion coefficient between X and Y
OK, so what is
[tex]Var\left(\frac{X+Y}{2}\right)[/tex]
Somehow, you need to show that it equals ρσ^2 + (1-ρ)σ^2/2.
The best thing I could do is :
Var(1/2(X+Y))= Var(1/2*X + 1/2*Y)= 1/4σx^2 + 1/4σy^2 + 2*1/4*ρ Sqrt(σx^2)*Sqrt(σy^2)
=1/4σ^2 + 1/4σ^2 +1/2*ρ*σ^2
but maybe I can rearrange this to your form ...I'll try it
Well, can you not rewrite that a bit to form ρσ^2 + (1-ρ)σ^2/2? Or you could work out what ρσ^2 + (1-ρ)σ^2/2 is...
yes, I can do it , so:
1/2σ^2 + 1/2*ρ*σ^2 = 1/2*(2ρσ^2-ρσ^2) + 1/2*σ^2 = ρσ^2 - 1/2*ρσ^2 + 1/2*σ^2
= ρσ^2 + 1/2*(σ^2-ρσ^2) = ρσ^2 + 1/2*(1-ρ)σ ^2
So the next step is to try it with n instead of 2 ?, I'll try that now
Very good!
The general step should be quite analogous...
The general step is then :
Var(1/n(X1+...+X2)) = 1/n*σ^2 + 2/n^2 *(1/2 * (n-1)n ) ρσ^2
= 1/n*σ^2 + (n-1)/n *ρσ^2
= ρσ^2 + 1/n*σ^2 + -1/n*ρσ^2
= ρσ^2 + 1/n*(1-ρ)σ^2
Seems fine! Well done! :smile:
Thanks !
Your hints where very helpful pointing me in the right direction.
Related to Statistics proof, identically distributed RVs and variance
1. What is a statistical proof?
A statistical proof is a method used to determine the validity of a hypothesis or claim by analyzing data. This involves using statistical techniques, such as hypothesis testing and confidence intervals, to make inferences about a population based on a sample.
2. What does it mean for random variables to be identically distributed?
Identically distributed random variables have the same probability distribution function. This means that the probability of obtaining a certain outcome is the same for each random variable. In other words, the variables are equally likely to occur and follow the same pattern of distribution.
3. How is the variance of a set of data calculated?
The variance of a set of data is calculated by taking the sum of the squared differences between each data point and the mean of the data, divided by the total number of data points. In other words, it measures how spread out the data is from the average.
4. What is the significance of variance in statistics?
Variance is an important measure in statistics as it provides information about the spread or variability of a set of data. It is used to calculate other important statistics, such as standard deviation and covariance, and is also used in hypothesis testing and confidence intervals.
5. How are variance and standard deviation related?
Variance and standard deviation are closely related, with the standard deviation being the square root of the variance. Both measures provide information about the spread of a set of data, but the standard deviation is more commonly used as it is in the same units as the data, making it easier to interpret.
