Statistics Question: The 3rd Moment of Poisson Distribution
In summary, X has a Poisson distribution with parameter L. The discrete mass function is f(x) = L^{x} e^{-L} / x!. E[X^3] is the third moment.
Legendre
62
X is a discrete random variable that has a Poisson Distribution with parameter L. Hence, the discrete mass function is [tex]f(x)[/tex] = [tex]L^{x} e^{-L} / x![/tex].
Where L is a real constant, e is the exponential symbol and x! is x factorial.
Without using generating functions, what is [tex]E(X^{3})[/tex]? (the 3rd moment)
N.A.
[tex]E(X^{3})[/tex] = [tex]\Sigma x^{3} L^{x} e^{-L} / x![/tex] from the definition of Expectation. Sigma is summation over all x values.
I think I am suppose to rearrange all the terms in order to get something of the form "{summation that sums to 1} times {answer}" but I totally lost regarding what I should be manipulating the terms into. Or maybe this is the wrong approach?
A little nudging would go a long way...and please don't give me the answer outright! Thanks in advance! :)
You can write:
x^3 = x (x-1)(x-2) + second degree polynomial in x
Count Iblis said:
You can write:
This looks so trivial on hindsight! How did you arrive at this insight? Or did you come across this from somewhere?
Thanks a lot! :)
I think it's a pretty common trick found in intro statistics courses. I mean the whole idea is that you don't have to compute any sums or integrals, but just recognize how to turn a particular sum or integral into something that is well-known. Since the pmf of the Poisson distribution has the factorial term in the denominator, it's pretty clear why finding E[X(X-1)*...*(X-k+1)] is a good step towards determining E[X^k]. Of course, to actually find E[X^k], you still have to determine E[x], E[x^2], ..., E[X^(k-1)], which still takes time even if you can determine a general formula for E[X(X-1)*...*(X-k+1)]. This is probably one hassle that makes the moment-generating method so attractive. Anyways the same trick applies to other distributions, e.g., the binomial distribution.
Thanks for the explanation. Sometimes I wonder if my brain is too slow to do mathematics.
But I am oh so addicted. :smile:
FAQ: Statistics Question: The 3rd Moment of Poisson Distribution
What is the 3rd moment of a Poisson distribution?
The 3rd moment of a Poisson distribution is a measure of the skewness of the distribution. It is calculated by taking the expected value of the cube of the difference between each data point and the mean of the distribution.
How is the 3rd moment of a Poisson distribution related to its shape?
The 3rd moment of a Poisson distribution can be used to determine the shape of the distribution. A positive 3rd moment indicates a right-skewed distribution, while a negative 3rd moment indicates a left-skewed distribution. A 3rd moment of 0 indicates a symmetrical distribution.
Why is the 3rd moment of a Poisson distribution important?
The 3rd moment of a Poisson distribution is important because it provides information about the shape of the distribution. This can help in understanding the data and making accurate predictions. It is also used in statistical tests and analyses.
How is the 3rd moment of a Poisson distribution calculated?
The 3rd moment of a Poisson distribution can be calculated using the formula E[(X-μ)^3], where X is the random variable, μ is the mean of the distribution, and E is the expected value operator. Alternatively, it can be calculated using the moment generating function.
Can the 3rd moment of a Poisson distribution be negative?
Yes, the 3rd moment of a Poisson distribution can be negative. This indicates a left-skewed distribution. However, it is more common for the 3rd moment to be positive, indicating a right-skewed distribution. A 3rd moment of 0 indicates a symmetrical distribution.
