huangdaiyu
- 5
For a fluid that is confined to a finite region with no sources and sinks, are the only options for the flow field a) static, and b) cyclic? The example I have in mind is Rayleigh convection in a shallow dish heated from below, where convection cells are formed beyond a certain temperature gradient. It seems reasonable to me that for a steady flow, the same fluid that leaves a small volume must pass through it again. But I don't know how to prove it. And it may not be true. I'm guessing the most relevant equation is continuity: ## \operatorname {div} \rho \mathbf{u} = 0##. But that's all I have so far. Intuitively, I think if fluid did not return to the same volume, then eventually there would be no fluid left that could fill it, and thus a vacuum would result. And that is definitely not steady state. But that's no proof.
