Steam produced heat transfer heat exchangers
The discussion centers on calculating the steam production from a fire tube boiler using flue gases. Dry saturated steam at 180°C is generated from cooling 50,000 kg/h of flue gases, which enter at 1600°C and exit at 200°C. The participants emphasize the importance of accounting for heat loss and using the correct latent heat of vaporization, which is 2015 kJ/kg at 180°C. They highlight the need for accurate unit conversions and calculations to determine the heat transfer and steam mass produced, ultimately arriving at a steam production estimate of 35,955 kg/h. The conversation also touches on the complexities of calculating the area of heat transfer required, noting that phase changes in boilers complicate standard heat exchanger equations.
Mitch1
Dry saturated steam at a temperature of 180oC is to be produced in a fire tube boiler from the cooling of 50 000 kg h–1 of flue gases from a pressurised combustion process. The gases enter the tubes of the boiler at 1600oC and leave at 200oC. The feed water is externally preheated to 180oC before entering the boiler.
The mean specific heat capacity of the flue gases is 1.15 kJ kg–1 K–1. The latent heat of vaporisation of the water at 180oC is 2015 kJ kg–1. Feed water temperature = 180oC.
Determine the amount of steam produced per hour, if the total heat loss is 10% of the heat available for steam raising.
Mass steam= heat available / heat required to produce 1kg steam
Qmc=heat transfer rate/ Cpc(tc2-tc1)
Heat transfer rate=Qmh hfg
Heat required would be 2257 from steam table at 100C evaporation
Heat available
Qmh hfg
50000*2015=10075x10^4 kW
Ht rate=10% of 10075x10^4 = 90675x10^3
Mass steam=heat available / heat req 1kg
Mass steam = 90675x10^3/2257
=40175 kg h-1
Can anyone check over this as I am unsure if it is correct
Thanks
Why? The feed water is being supplied already pre-heated to 180 C
Heat available
Qmh hfg
The units here are not kW. 1 W = 1 J/s, and 1 hour ≠ 1 second
Show the units here and carry thru with the multiplication. That's how to avoid mistakes.
Mass steam = 90675x10^3/2257=40175 kg h-1
As mentioned above, the feed water is already pre-heated to 180 C when it enters the heat exchanger. The problem statement tells you that the latent heat of vaporization is 2015 kJ/kg for water at 180 C.
The enthalpy of steam at 100 C is irrelevant here.
Thanks for your reply
Ah so if I work out the correct units and carry it through I will divide it by 2015 which is at 180C ? Does the rest Seem ok?
The heat supplied by the flue gas seems to have been overlooked. The gas enters at a temp. of 1600 C and leaves at a temp. of 200 C. The specific heat capacity of the flue gas is 1.15 kJ/kg-K. You've got to work out how much heat is available to be transferred from the gas to the feed water to make steam.
Hi again,
To find out this is this the spec heat*temp difference
I'm not that clued up on this subject
Once this is found is this part of the heat available
Mitch1 said:
Hi again,
Yes. You are transferring the heat from the flue gas to the feed water to turn it into steam. Remember to include the 10% heat loss in your calculations of steam production.
So it would be 1400*1.15*.9 for the ten percent heat loss which gives 1449 kW I'm assuming?
So is this the heat available? Then we divide it by 2015 the enthalpy at 180C ?
I believe I am missing a step out as this seems too low of a value
Again, you need to show and carry thru the units in these calculations. You are just assuming what units appear in the results.
You've also neglected to include the flow rate of the flue gases in your heat calculations, which is why the result appears so low.
For the heat available:
H = eff. * flow * cp * ΔT, which has units
H = kg/hr * kJ/kg-K * K
H = kJ/hr, which is not the same units as kW, so stop calling the heat rate kW
So, (1600-200)*1.15*.9*50,000=72450000kj/hr
7245x10^4/2015=35955kg/hr ?
This looks better.
SteamKing said:
This looks better.
Finally,
Thanks for your help!
On the same question: The overall heat transfer coefficient based on outside area of the tubes is given as 54 Wm K .Determine the area of heat transfer required to perform this duty
Are these units correct?
Should be Wm^-2 K^-1
Good. Now, what's the equation for the heat transfer in a heat exchanger?
I'm new to this forum and not sure yet how to write down the symbols, but heat transfer= Phi = U A (LMTD).So finding A would be phi/U(LMTD).Finding the LMTD is proving difficult as I'm not sure of the outlet temp of the feed water.
It's not clear what you are trying to analyze here.
The original problem involved a fire tube boiler. The conditions at which the boiler produced steam were not disclosed in the OP. The only thing you know for certain is that the feed water entered the boiler at 180° C.
If you refer to the first post from Mitch1 all the details of the first part are there.The second part of the question is asking for the area required to perform this duty when the overall heat coefficient is 54 Wm^-2 K^-1
Good. You have a pool of water boiling at 180oC producing steam at 180oC. What might the water temperature be everywhere outside the tubes?
Of course it's obvious when you look at it logically.Thanks for the heads up.I can know find the LMTD and ultimately find the required area
Hi,
I have a query to what lycee was trying to work out.
When working out the LMTD I keep getting a negative number. My working is as follows:
LMTD = (Tc1 -Tc2) / In[(Th-Tc1)/(Th-Tc2)]
Where I have:
Th = 180°C
Tc1 = 1600°C
Tc2 = 200°C
Subbing those values in gives me an answer of -328.41°C.
Do I have the values correct? Or even the equation?
Thank you in advance for any response.
Your LMTD equation is incorrect.
MCTachyon said:
Hi,
Where I have:
Th = 180°C
Tc1 = 1600°C
Tc2 = 200°C
You can't calculate a valid LMTD for a boiler since there is latent heat involved.
https://en.wikipedia.org/wiki/Logarithmic_mean_temperature_difference
Is the equation I want:
LMTD = (Tc1-Tc2) / [(In(Tc1) - In(Tc2))]
Therefore:
1400 / 2.07 = 676.33°C
*Source for that equation from Wiki page SteamKing posted.Edit: I've just looked again.. The equation on the Wiki page mentions temperature change at points A and B. Not set temperatures.
Lemme have some time with this today and I'll report back. The only equation I know for the LMTD is the one I originally stated.
Having worked out correctly what Mich1 was trying to work out, I now have the values for:
qm = 35955 kgh-1
Φ = 72.45 x 106kJh-1
I am now trying to work out the area of heat transfer if the overall heat transfer coefficient based on the outside area of the tubes is given as:
U = 54 Wm-2k-1
I am now using the equation:
Φ = UA(LMTD)
Rearranged for A:
A = Φ / (U x LMTD) ..
So far so good?
qm = 35955 kgh-1
U = 54 Wm-2k-1
Φ = UA(LMTD)
Rearranged for A:
So far so good?
Yeah, except boilers don't work with LMTD because the fluid inside them is undergoing a phase change. The boiler furnishes the latent heat required to turn the feed water into saturated vapor, and this process occurs at constant temperature.
The opposite occurs in the condenser. The condenser removes the latent heat of vaporization from the incoming steam and turns it back into saturated liquid. This process occurs at constant temperature, also.
You can't analyze a boiler or a condenser like it was any other heat exchanger.
The following attachment shows the calculations for a student-designed fire tube boiler:
http://u.osu.edu/joesportfolio/files/2015/01/Three-Phase-Water-Boiler-2253n42.pdf
Thank you. I will go through this PDF and have another stab.
Ta,
Right I've had a good go at this over weekend and haven't got any closer to answering.
There is an equation on the PDF I was playing with to try and pulling something together but think I am completely barking up the wrong tree.
The equation being:
Q = A [(Tair-Tw) / (1/hair+ttube/Ktube+1/hw)]
We are not given the thickness of tubes to work this equation out though.
I have tried reading further into the thermal design of fire tube boilers on other sites and seem to have the same equations I was encountering before.
Sorry to have dragged this out. I spent so long on the LMTD route that my train of thought probably isn't on the right track at all.
The equation being:
From what I remember about boiler design (I studied marine engineering at college), the characteristics of the tubes were important to the heat transfer occurring inside the boiler itself.
The original problem was never about the heat transfer through the tubes into the feed water, but about the gross heat energy which was available in the flue gasses, therefore, the right design information for the tubes was not provided.
I have specified dozens of condensers and boilers and used LMTD successfully. Since simple phase-change boiling or condensing cannot have a temperature cross, no correction to LMTD is needed.
Given the statement of the problem, I don't know of any other approach.
MCTachyon, you still haven't got the correct LMTD.
11K
  • · Replies 51 ·
9K
  • · Replies 20 ·
