Steel grade of commercially available MS channels, MS plates
In summary, the steel grade of commercially available mild steel channels and MS plates can vary depending on the country of origin. In the US, the standard is ASTM A36, while in Europe and Japan, it may be produced according to national standards such as BS or JIS. It is best to check with the supplier for the specific steel grade used in their products.
Hiam2015
What is the steel grade of commercially available mild steel channels (say MC 125) and MS plates (say 4mm MS sheets)?
Depends on the source. Different countries have different standards for producing mild steel.
The basic mild steel produced in the US, for instance, is ASTM A36.
In Europe, the steel products there may be produced to one of several different national standards, like BS or DIN. Ditto steel from Japan, the JIS standard.
In most cases, check with a supplier to find out what standards are used to make their products.
FAQ: Steel grade of commercially available MS channels, MS plates
1. What is the difference between MS channels and MS plates?
The main difference between MS channels and MS plates is their shape and size. MS channels are shaped like a "C" or "U" and are generally used for structural support, while MS plates are flat and can be cut into custom sizes for various applications.
2. What is the steel grade of commercially available MS channels and MS plates?
The most commonly used steel grade for commercially available MS channels and MS plates is ASTM A36, which has a minimum yield strength of 36,000 psi.
3. Are there any other steel grades available for MS channels and MS plates?
Yes, there are other steel grades available for MS channels and MS plates, such as ASTM A572, which has a higher yield strength of 50,000 psi.
4. What is the thickness range for MS plates?
The thickness range for MS plates can vary depending on the manufacturer, but it typically ranges from 1/4 inch to 4 inches.
5. Can MS channels and MS plates be used for outdoor applications?
Yes, MS channels and MS plates can be used for outdoor applications as they are made from steel, which has high strength and durability. However, it is important to use a corrosion-resistant coating or paint to protect them from the elements.
