Stein-Shakarchi 'Complex Analysis' Chapter 3 Exercise 15 b.
In summary, the maximum modulus principle and Cauchy's inequalities can be used to show that the given function $f$ must be identically $0$, as it converges uniformly to $0$ in the sector $\theta < \text{arg}(z) < \varphi$ as $|z| \to 1$.
caffeinemachine
MHB
816
I am stuck on a problem given in Stein and Shakarchi's Complex Analysis.
(Chapter 3, Exercise 15b) Use the maximum modulus principle or Cauchy inequalities to solve the following:
Let $f$ be a bounded holomorphic function on the open unit disc, and suppose that $f$ converges uniformly to $0$ in the sector $\theta< \text{arg}(z)< \varphi$ as $|z|\to 1$. Then show that $f$ is $0$.
In other words, we have a bounded holomorphic function on the open unit disc with the following property:
For all $\varepsilon>0$, there is $r$ with $0< r< 1$ such that whenever $1>|z|>r$ with $\theta< \text{arg}(z)< \varphi$, we have $|f(z)|<\varepsilon$.
We want to show that $f$ is identically $0$.
I have been unable to make any progress on this problem. Can somebody help. Thanks.
I can offer some guidance on how to approach this problem. First, let's recall the maximum modulus principle, which states that for a holomorphic function $f$ on a bounded open set $\Omega$, the maximum value of $|f|$ on $\Omega$ must occur on the boundary of $\Omega$. This can also be extended to the maximum modulus principle for harmonic functions, which states that the maximum value of a harmonic function on a bounded open set $\Omega$ must also occur on the boundary of $\Omega$.
Now, let's consider the function $g(z) = \frac{1}{z}$, which is holomorphic on the open unit disc. We know that $|g(z)| = \frac{1}{|z|}$, so as $|z| \to 1$, $|g(z)| \to 1$. This means that for any $\varepsilon > 0$, we can find $r$ such that whenever $1 > |z| > r$, we have $|g(z)| < \varepsilon$.
Next, we can use Cauchy's inequalities, which state that for a holomorphic function $f$ on a disc of radius $R$, we have $|f^{(n)}(0)| \leq \frac{n!}{R^n}\sup_{|z|=R}|f(z)|$. Applying this to our function $f$, we have $|f(z)| \leq \frac{n!}{R^n}$ for all $z$ with $|z| = R$.
Now, using the fact that $f$ converges uniformly to $0$ in the sector $\theta < \text{arg}(z) < \varphi$, we can find $r$ such that for all $z$ with $\theta < \text{arg}(z) < \varphi$ and $r < |z| < 1$, we have $|f(z)| < \varepsilon$. This means that $|f^{(n)}(0)| \leq \frac{n!}{R^n}\varepsilon$ for all $n$, and since $\varepsilon$ can be made arbitrarily small, we have $f^{(n)}(0) = 0$ for all $n$. This implies that $f$ is identically $0$, since its Taylor series at $
FAQ: Stein-Shakarchi 'Complex Analysis' Chapter 3 Exercise 15 b.
What is the main concept behind Exercise 15 b in Chapter 3 of Stein-Shakarchi's 'Complex Analysis'?
The main concept behind Exercise 15 b is the Cauchy-Riemann equations, which relate the partial derivatives of a complex-valued function to its analyticity, or differentiability. This exercise specifically deals with finding functions that satisfy the Cauchy-Riemann equations and determining their corresponding analytic functions.
Can you explain the Cauchy-Riemann equations in simpler terms?
The Cauchy-Riemann equations state that for a complex-valued function f(x+iy) to be differentiable at a point z0=x0+iy0, the partial derivatives of its real and imaginary parts must exist and satisfy the following conditions:
- The partial derivative of the real part with respect to x must equal the partial derivative of the imaginary part with respect to y.
- The partial derivative of the real part with respect to y must equal the negative of the partial derivative of the imaginary part with respect to x.
How can I determine if a given function satisfies the Cauchy-Riemann equations?
To determine if a function satisfies the Cauchy-Riemann equations, you can take the partial derivatives of its real and imaginary parts and check if they satisfy the conditions mentioned in answer #2. If they do, then the function is analytic at that point. However, keep in mind that this is only a necessary condition for analyticity - it does not guarantee that the function is differentiable at that point.
What is the significance of analytic functions in complex analysis?
Analytic functions play a crucial role in complex analysis as they are the most well-behaved functions in the complex plane. They are infinitely differentiable and have a number of important properties, such as the Cauchy integral theorem and Cauchy integral formula, which make them useful for solving problems in various fields, including physics, engineering, and economics.
Can you provide an example of a function that satisfies the Cauchy-Riemann equations?
One example of a function that satisfies the Cauchy-Riemann equations is f(z) = x^2 + iy^2. Its real part, u(x,y) = x^2, has partial derivatives with respect to x and y of 2x and 0, respectively. Its imaginary part, v(x,y) = y^2, has partial derivatives with respect to x and y of 0 and 2y, respectively. These values satisfy the conditions of the Cauchy-Riemann equations, making the function analytic at all points in the complex plane.
