MHB Stephen's question at Yahoo Answers regarding an inhomogeneous linear recurrence
  • Thread starter Thread starter MarkFL
    Linear Recurrence
The discussion addresses Stephen's question about finding the closed form of the recurrence relation A_n = A_{n-1} + 2n + 1 with A_1 = 1. The analysis shows that the closed form will be quadratic due to the linear difference between successive terms. By applying symbolic differencing and solving a system of equations derived from initial values, the parameters are determined as k_1 = -2, k_2 = 2, and k_3 = 1. Consequently, the closed form is established as A_n = n^2 + 2n - 2. The conversation encourages further inquiries into recurrence relations in a dedicated math forum.
MarkFL
MHB
Here is the question:
Find The Closed Form?
A1 = 1
an-1 + 2n+1
I know how to get the sequence but I don't know how to write the closed form.
Here is a link to the question:
Find The Closed Form? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Hello Stephen,
We are given the recurrence:
$$A_{n}=A_{n-1}+2n+1$$ where $$A_1=1$$
Now, if we write the recurrence as:
$$A_{n}-A_{n-1}=2n+1$$
we can see that the difference between two successive terms is a linear function in $n$ and so we know the closed form will be quadratic. Let's take the time to look at a method called symbolic differencing to show that this must be true. Let's begin with the given recurrence:
We may now increase $n$ by one to write the recurrence equivalently as:
$$A_{n+1}=A_{n}+2(n+1)+1$$
Subtracting the former from the latter, we obtain:
$$A_{n+1}=2A_{n}-A_{n-1}+2$$
$$A_{n+2}=2A_{n+1}-A_{n}+2$$
$$A_{n+2}=3A_{n+1}-3A_{n}+A_{n-1}$$
We now have a homogeneous recurrence, whose associated characteristic equation is:
$$r^3-3r^2+3r-1=(r-1)^3=0$$
Because the characteristic roots are $r=1$ of multiplicity 3, we know the closed form is:
$$A_n=k_1+k_2n+k_3n^2$$
where the parameters $k_i$ may be determined by initial values.
We are given:
$$A_1=1$$
and so using the original inhomogeneous recurrence, we may compute the next two terms:
$$A_2=1+2(2)+1=6$$
$$A_3=6+2(3)+1=13$$
Now we have enough values to determine the parameters. We obtain the following 3X3 system:
$$A_1=k_1+k_2\cdot1+k_3\cdot1^2=k_1+k_2+k_3=1$$
$$A_2=k_1+k_2\cdot2+k_3\cdot2^2=k_1+2k_2+4k_3=6$$
$$A_3=k_1+k_2\cdot3+k_3\cdot3^2=k_1+3k_2+9k_3=13$$
Solving this system, we find:
$$k_1=-2,\,k_2=2,\,k_3=1$$
and so the closed form for the recurrence is:
$$A_n=-2+2n+n^2=n^2+2n-2$$
To Stephen and any other guests viewing this topic, I invite and encourage you to post other recurrence or difference equation questions in our http://www.mathhelpboards.com/f15/ forum.
Best Regards,
Mark.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
