Steps for converting one type of graph to the other?
  • Thread starter navneet9431
  • Tags
    Graph Type
In summary, when plotting a position time graph from a velocity time graph, there are a few key considerations to keep in mind. The position should always be increasing, with the velocity remaining positive. Additionally, the rate of increase in position should also be increasing, represented by a curve that turns upwards. It is important to accurately map the rate of increase, particularly towards the end where the velocity appears to approach a constant. Finally, the beginning of the curve should start with a flatter slope. If given a specific question about plotting the graph, more information should be provided on how the sketch was determined, such as the reason for the increasing slope.
navneet9431
Suppose this the velocity time graph given and we want to plot position time grah from this.
What are the things to be considered while plotting the position time graph from this graph?
2. Homework Equations
The uniform acceleration motion equations.
I think this is what the graph should look like because area under the velocity time cure is continuously increasing.
I will be thankful for any help!
The position is always increasing = the velocity is always positive, good.
The rate of the increase in position is increasing (the curve turns upwards) = the velocity is increasing, good.
You start with zero velocity, the beginning of the curve could be a bit flatter.
Mapping the rate of this increase accurately is difficult. Towards the end it looks like the velocity approaches a constant, so the position graph should become close to a straight line.
Likes navneet9431
Mark44 said:
@navneet9431, the word is "graph" not "grah".
I have edited it!
Is that the question asked of you, or were you asked to sketch the graph and this is your question to the forum?
If the first, you need to say more about how you arrived at the sketch. Specifically, explain why you have the slope increasing.
Related to Steps for converting one type of graph to the other?
1. How do I convert a bar graph to a line graph?
To convert a bar graph to a line graph, you will need to plot the data points for each category represented in the bar graph on a scatter plot. Then, connect the data points with a line to create the line graph.
2. Can I convert a pie chart to a bar graph?
Yes, you can convert a pie chart to a bar graph by converting the percentages or fractions represented in the pie chart into numerical values and plotting them on a bar graph.
3. What is the process for converting a scatter plot to a histogram?
To convert a scatter plot to a histogram, you will need to group the data points into categories or bins and then plot the frequency of data points falling within each bin on the histogram.
4. Is it possible to convert a line graph to a scatter plot?
Yes, you can convert a line graph to a scatter plot by taking the data points represented by the line and plotting them individually on a scatter plot.
5. Are there any tools or software that can automatically convert one type of graph to another?
There are some software programs that have the capability to convert one type of graph to another, such as Microsoft Excel. However, it is important to manually check and adjust the converted graph to ensure accuracy and proper representation of the data.
