MHB Steps for Setting Up Triple Integrals
To set up triple integrals, start by sketching the region of integration to visualize its boundaries. Identify the limits for each variable based on the geometry of the region, such as a right circular cylinder or a sphere. For example, a cylinder defined by z=0, z=h, and x²+y²=r² leads to specific bounds: 0≤z≤h, -r≤y≤r, and -√(r²-y²)≤x≤√(r²-y²). Using symmetry can simplify the integral setup, allowing for more efficient calculations. This method provides a structured approach to evaluating volumes using triple integrals.
harpazo
I am really struggling setting up triple integrals. I need steps, simple steps normally applied when setting up integrals given a specific region.
Well the first step is always drawing a sketch of your region...
Ok but can you provide steps? Find the bounds has been a big challenge for me. I can easily integrate when the set up is given.
Let's look at a very simple example. Consider the region bounded by:
$$z=0$$
$$z=h$$
$$x^2+y^2=r^2$$
When we make a sketch of the region, we see is is a right circular cylinder of radius $r$ and height $h$, so we know its volume is $V=\pi r^2h$. To set up a triple integral to compute the volume, we see that:
$$0\le z\le h$$
$$-r\le y\le r$$
$$-\sqrt{r^2-y^2}\le x\le\sqrt{r^2-y^2}$$
And so we may express the volume as:
$$V=\int_0^h\int_{-r}^{r}\int_{-\sqrt{r^2-y^2}}^{\sqrt{r^2-y^2}}\,dx\,dy\,dz$$
Using symmetry, we may state:
$$V=4\int_0^h\int_{0}^{r}\int_{0}^{\sqrt{r^2-y^2}}\,dx\,dy\,dz$$
Evaluating, we have:
$$V=4\int_0^h\int_{0}^{r}\sqrt{r^2-y^2}\,dy\,dz=\pi r^2\int_0^h\,dz=\pi r^2h\quad\checkmark$$
Likewise, a sphere of radius $r$ can be set up as follows:
$$V=8\int_0^r\int_0^{\sqrt{r^2-z^2}}\int_0^{\sqrt{r^2-y^2}}\,dx\,dy\,dz$$
Draw a sketch of a sphere centered at the origin of radius $r$ and see if you can confirm these limits. :D
$$z=0$$
$$z=h$$
$$x^2+y^2=r^2$$
$$0\le z\le h$$
$$-r\le y\le r$$
An excellent explanation. Thanks.
There are probably loads of proofs of this online, but I do not want to cheat. Here is my attempt: Convexity says that $$f(\lambda a + (1-\lambda)b) \leq \lambda f(a) + (1-\lambda) f(b)$$ $$f(b + \lambda(a-b)) \leq f(b) + \lambda (f(a) - f(b))$$ We know from the intermediate value theorem that there exists a ##c \in (b,a)## such that $$\frac{f(a) - f(b)}{a-b} = f'(c).$$ Hence $$f(b + \lambda(a-b)) \leq f(b) + \lambda (a - b) f'(c))$$ $$\frac{f(b + \lambda(a-b)) - f(b)}{\lambda(a-b)}...
