Stereographic projection in de Sitter cosmological model
In summary, general relativity allows for any change of coordinates as long as it is a diffeomorphism. This means that conformal transformations, which involve more than just relabeling, are still allowed. In contrast, in de Sitter's model, stereographic projection was used to obtain a metric in static coordinates, but this can't be applied in general relativity where transformations must be isometric. However, this is not true as any change of coordinates is valid in general relativity. Thank you to bcrowell for clarifying this.
ahmad2l
We know stereographic projection is conformal but it isn't isometic and in general relativity it can not be used because in this theory general transformations must be isometric. But de sitter in his model (1917) used it (stereographic projection) to obtain metric in static coordinates. How can it be explained
Not true. In GR, any change of coordinates is legal as long as it's a diffeomorphism. There is no additional requirement.
In GR, when you do a change of coordinates, you change both the coordinates and the elements of the metric tensor itself. The result is that everything automatically still remains consistent. You're still describing the same spacetime, and it's still a solution to the field equations. All you've done is relabel everything. As a simple exampls, if you take Minkowski space and rescale all the coordinates by a factor of 1/2, and the metric was (+1,-1,-1,-1) in the original coordinates, then the metric in the new coordinates is (+4,-4,-4,-4).
When you talk about things like conformal transformations, you're not talking about a change of coordinates. It's more than a relabeling. For example, you can define a conformal transformation like [itex]g\rightarrow \Omega^2 g[/itex], while still leaving all the points fixed and describing them with the same coordinates. Or, alternatively, you can define conformal transformations that send points to other points, while leaving the metric the same. (This is how people typically think about conformal transformations in the complex plane.)
thank you bcrowell. you saved me
Related to Stereographic projection in de Sitter cosmological model
1. What is stereographic projection in the de Sitter cosmological model?
Stereographic projection is a geometric method used to map points on a sphere onto a plane. In the context of the de Sitter cosmological model, it is used to map the points on a 4-dimensional hyperbolic space onto a 3-dimensional flat space.
2. How does stereographic projection work in the de Sitter cosmological model?
In stereographic projection, a point on the sphere is projected onto the plane by drawing a line from the point, through the opposite pole (which is a fixed point on the plane), and onto the plane. In the de Sitter cosmological model, this process is repeated for each point on the 4-dimensional hyperbolic space, resulting in a 3-dimensional flat space.
3. What is the significance of stereographic projection in the de Sitter cosmological model?
Stereographic projection allows us to visualize and analyze the de Sitter cosmological model, which describes a universe with a constant expansion rate and positive cosmological constant. It helps us understand the geometry and dynamics of this model, and is a useful tool for making predictions and testing hypotheses.
4. How is stereographic projection related to the concept of conformal symmetry in the de Sitter cosmological model?
In the de Sitter cosmological model, there is a special type of symmetry called conformal symmetry, which preserves the angles between points on the 4-dimensional hyperbolic space. Stereographic projection is a form of conformal mapping, meaning it preserves angles and thus maintains the conformal symmetry of the model.
5. Can stereographic projection also be used in other cosmological models?
Yes, stereographic projection can be used in other cosmological models to map points on a curved space onto a flat space, allowing for easier visualization and analysis. However, the specific geometric properties and dynamics of each model will determine the specific method and application of stereographic projection.
  • Beyond the Standard Models
  • Quantum Physics
