Stern-Gerlach experiment with a classical object
In summary, the conversation discusses the setup of a classical analog of the SG experiment within classical physics, with the goal of understanding the relevant forces at play. The experiment involves a macroscopic magnet setup with identically built compasses, where the initial orientation and angular momentum of the needle are random. The conversation explores the torque applied by the magnetic field on the compass needle and its effect on the orientation and magnetic moment of the needle. The conversation also discusses the potential for using friction and energy loss through EM-radiation to achieve a stable equilibrium. Finally, there is a discussion of the appropriate analog for this experiment and the role of torque in the experiment.
Killtech
344
35
TL;DR Summary
looking for help calculating Stern-Gerlach experiment for classical objects like a compass used instead of a particle
I want to have a make/calculate a classical analog of the SG experiment within classical physics to understand all the relevant forces at play here. Within this context i would like to stick to classical physics only (yeah, I want it to compare to QM later but that is besides the discussion) and I hope to get some help in getting this right.
So the general setup of the experiment (the SG device) is macroscopic magnet setup which as such can be used identically. To make it practical everything should happen in zero-G and vacuum (no friction nor gravity). Instead of a quantum particle I want take identically build compasses with a frictionless mounted magnetic needle. Let the initial orientation and angular momentum of the needle be random/unknown.
Okay, now my understanding is that once a compass enters the magnetic field this will apply a torque through the magnetic moment of the needle – I want to setup the parameters such that the change of the angular momentum becomes significant compared to the magnetic gradient dipole force – so the needle needs to have extremely low mass and enough flight time in the SG device while the magnetic field needs to be low and the compass itself heavy to reduce the deflection of the entire body.
Anyhow the torque will however change the orientation of the needle and thus that of its magnetic moment which again should change its torque. The combined ODE for the needles angle should look just like for a pendulum in a gravity field (making some simplifying assumptions like a negligible deflection angle of the compass to keep the ##B## field near constant along the path), right?
Now assuming the needles oscillates fast enough couldn’t I just simplify things for the effective deflecting force acting on the compass by just taking the average magnetic moment vector of the needle over an entire oscillation period? Now I am not sure what the best method is to calculating these averages for a no-small-angle approximation pendulum. Any ideas?
Without calculation I would expect that in the case a) where the needles moment is exactly aligned along the magnetic field already it shouldn’t move so the effective moment should stay the same. In case where it a different orientation b) it should be a reduced value but always parallel to the magnetic field because the oscillation must be symmetric around the pivot point. c) If the needle is close to making a full circle or slightly faster than that (i.e. around the unstable equilibrium) it should spend most time upside down resulting in having an average magnetic momentum antiparallel to ##B## and if it spins too fast d) the total deflecting force should even net out to zero.
Now if I wanted to get discrete deflection angles shouldn’t it be sufficient to add a little friction to the needle to get a dampened oscillation that will converge the needle towards the only stable configuration? Unfortunately this makes only the pivot point parallel to ##B## stable while the unstable equilibrium at ##\phi=\pi## would swiftly decay. Then again one could cheat a little with a less trivial friction model e.g. by also adding static friction to make it stable.
Assuming everything is scaled up to dimensions that allow the oscillation to settle at an equilibrium long before leaving the SG device, shouldn’t this result in the deviation angles of the outgoing compasses amass around two points only and where the proportions of those two populations would depend on the initial condition/angular distribution/friction model?
Also what would happen if instead of considering friction I would take energy loss through EM-radiation into account? Given that I have a spinning dipole shouldn’t this oscillation classically lose energy (and therefore angular momentum)? Is there an analogue Larmor formula for that particular case?
Okay, before i get into a thorough calculation i would like to now if that setup/assumptions are reasonable first or if there are any logical errors i made.
The appropriate analog would be a spinning sphere magnetized along its axis of rotation. Shooting such a projectile through an SG magnet will cause it to deflect as a smooth function of its component of spin in the direction the SG magnet is set up. This was the expected outcome for elementary particles and the surprise was that the respective spin component was quantized with only the two values.
The spinning allows the object to keep its angle with respect to the magnetic field even with the torque the field applies. It instead precesses. The asymmetric non-linearity of the SG magnet's field causes the deflecting force.
Likes vanhees71 and PeroK
Well, my intention here was specifically to understand the role the torque can play, which is why I set it up to give it a greater importance. In particular i do want to see what happens if the object can change its angle with respect to the ##B##.
A spinning sphere would exhibit a different behavior as you noted, therefore it isn't what I was looking for. Also a homogeneous sphere shouldn't be able to lose any energy to radiation like an spinning rod magnet (the compass needle) would - therefore it cannot use that effect to dampen its oscillation either.
Related to Stern-Gerlach experiment with a classical object
1. What is the Stern-Gerlach experiment with a classical object?
The Stern-Gerlach experiment with a classical object is a thought experiment that illustrates the concept of quantum superposition. It involves passing a beam of particles, such as atoms or electrons, through an inhomogeneous magnetic field and observing the resulting deflection of the particles.
2. What is the purpose of the Stern-Gerlach experiment with a classical object?
The purpose of the Stern-Gerlach experiment with a classical object is to demonstrate the quantization of angular momentum in quantum systems. It also serves as evidence for the existence of spin in particles, which is a fundamental property of quantum objects.
3. How does the Stern-Gerlach experiment with a classical object work?
In the experiment, a beam of particles is passed through an inhomogeneous magnetic field, which causes the particles to split into two or more beams. This is due to the fact that the magnetic field interacts differently with particles that have different spin orientations. The resulting deflection of the particles can be observed and measured.
4. What is the significance of the results from the Stern-Gerlach experiment with a classical object?
The results of the Stern-Gerlach experiment with a classical object provide evidence for the quantization of angular momentum in quantum systems. They also support the concept of superposition, which states that particles can exist in multiple states simultaneously. This experiment has played a significant role in the development of quantum mechanics.
5. How does the Stern-Gerlach experiment with a classical object differ from the original experiment with silver atoms?
The original Stern-Gerlach experiment was conducted with silver atoms, which are quantum objects. In this experiment, the particles were observed to split into two beams, with each beam having a specific spin orientation. In contrast, the Stern-Gerlach experiment with a classical object uses classical particles, such as macroscopic objects, and does not exhibit the same quantization of angular momentum as seen in the original experiment.
  • Quantum Physics
