Stern-Gerlach Inferometer (I don't understand the lecturer)
In summary: In this case, it is guaranteed to have +m(x) spin. (Remember that the interferometer does nothing to the atom unless it's blocked.) So factor is 1.6. In summary, the atom has a 1/4 chance of being +m(x) and a 1/4 chance of being -m(x) after passing through the GS.
unscientific
1,734
This isn't exactly a homework question, but rather from the lecturer's slides. I'm not sure if I understand what's going on.
Branch a is blocked
1. Atoms all with +ve spin enter
2. all the atoms can approach the terminal a (+)
3. Just before crossing over the gap, half tries to go through a(+), half tries to go through b(-). factor = 1/2
4. atoms passes through b, +ve spin gets converted into -ve spin
5. second analyser at 90o, so splits into cos2(90/2) = 1/2 with +ve spin, splits into 1 - cos2(90/2) = sin2(90/2) 1/2 with -ve spin factor = 1/2
6. Result: 1/4 with -ve spin, 1/4 with positive spin. Ones with +ve spin approaches and crashes at blue barrier. Ones with -ve spin approaches below. Result = 1/4 -ve spin.
Neither Branch is blocked
1. atoms approach a(+)
2. Just before crossing over, splits into a(+) and (b-); factor = 1/2
3. Recombines. factor becomes 1.
4. second analyser at 90o, so splits into cos2(90/2) = 1/2 with +ve spin, splits into 1 - cos2(90/2) = sin2(90/2) 1/2 with -ve spin factor = 1/2
5. Result: 1/2 with -ve spin, 1/2 with positive spin. Ones with +ve spin approaches and crashes at blue barrier. Ones with -ve spin approaches below. Result = 1/2 -ve spin.
But, from the slides I can infer that going to an inferometer that's 90 degrees does not change the particle's spin at all..if it's all +ve heading towards a perpendicular inferometer, it remains +ve.
However, this seems to contradict what I'm currently reading, which is also notes provided by the same lecturer. It suggests that passing from a z-plane to a x-plane stern-gerlach apparatus appears to 'reset' the spins back to having both +ve and -ve.
90° relative to what?
The spin is not changed if the initial spin is aligned with the polarization axis of the interferometer.
The spin is changed if there is an angle between both.
What I meant was suppose the atom (initially with +spin) travels from a z-plane GS to an x-plane GS (Which is 90o to the z-plane), the atom now has 2 spins, both +ve and -ve but with a factor of cos2(α/2) in the +ve spin, sin2(α/2), in the -ve spin where α is the angle between plane.
In which direction?
Right.
mfb said:
In which direction?
In the z+ direction.
1. If branch a is blocked, why does the intermediate atom have -m spin? Is it because it passes through b? Does this mean that each time it crosses a gap it acquires a spin that is either +ve/-ve, depending on where it passes through?
Right.
Right
Ok, I think I have resolved it!
1. First of all, i wrongly assumed that the atom having +m(z) is the same as +m(x). I didn't realize that they are different axes. If no branches are blocked, the interferometer does nothing to the atom, regardless of it's orientation.
2. Initial stage, we have no clue whether the atom is +m(x) or -m(x) oriented. The only way to tell is to see where it passes through - (If it passes through a, it must be +m(x) then, if it passes through b, it must be -m(x) then.) We have no information beforehand. So factor = 1/2.
3. Suppose a is blocked. Then anything passes through b will be of -m(x). Knowing precisely its spin is -m(x), we can't determine its spin in m(z) (Weird I know). When it passes into the final GS, it can either be +m(z) or -m(z) (again, we can only tell after it passes through the output). So factor is 1/2.
4. Now if neither branch is blocked, we know clearly that the atom is +m(z) since the interferometer does nothing to the atom. But we have no information on its m(x) spin. Now certain of it being +m(z), it must pass through the + terminal at the final GS. Hence 0 probability.
5. Now consider this scenario, where we "explicitly" evaluate probabilities at a point. The atom can either go through a or b. Then it can either go through + or - at the final GS. P(through a) = 1/4, P(through b) = 1/4. So total probability = 1/2. But, the problem here lies with the assumption that the atom "either goes through a or b", because since we know for definite that its spin is +m(z), we cannot say what its spin in m(x) is (Not unless you observe it throughout)
6. It appears that when you observe the atom entirely (passing through a/b, entering the GS). The probability of the atom passing from the input to the output is 1/2. But when you if you just let the atom do whatever it wants without watching (interacting) it, the probability is 0. So clearly, an atom behaves differently when it's being watched than it being unwatched.
FAQ: Stern-Gerlach Inferometer (I don't understand the lecturer)
What is a Stern-Gerlach interferometer?
A Stern-Gerlach interferometer is a device used in quantum mechanics to measure the spin of particles, such as electrons or atoms. It consists of a series of magnets that split a beam of particles into two paths based on their spin orientation.
How does a Stern-Gerlach interferometer work?
The particles in a Stern-Gerlach interferometer are sent through a series of magnets that have different orientations. The magnets exert a force on the particles depending on their spin orientation, causing them to be deflected in different directions. This allows the particles to be separated based on their spin.
What is the purpose of a Stern-Gerlach interferometer?
The purpose of a Stern-Gerlach interferometer is to measure the spin of particles. It is a valuable tool in quantum mechanics research as it allows for the precise measurement of a particle's spin, which is an important quantum property.
What are some applications of the Stern-Gerlach interferometer?
The Stern-Gerlach interferometer has various applications, including studying quantum effects, testing quantum theories, and measuring the magnetic moment of particles. It is also used in technologies such as magnetic resonance imaging (MRI) and atomic clocks.
How is the Stern-Gerlach interferometer different from other measurement devices?
The Stern-Gerlach interferometer is unique in its ability to measure the spin of particles precisely. Other devices, such as Stern-Gerlach detectors, can only measure the spin in one direction, while the interferometer can measure the spin in multiple directions simultaneously. Additionally, the interferometer is not affected by external magnetic fields, making it a more accurate measurement tool.
11K
