Stern-Gerlach Separation Distance on Target Film
In summary, the separation distance between the two impact zones of Sodium atoms on a photographic plate is 0.0047m.
Quelsita
49
I have a question in which we are instructed to find the separation distance between the two impact zones of Sodium atoms on a photographic plate:
A magnet of length l= 0.15m and field gradient [tex]\nabla[/tex]B= 9.0T/m over its full length is used in a Stern-Gerlach experiment. If a beam of Sodium atoms of velocity v=600m/s passes through this magnet and then strikes a photographic plate at a distance of d=0.80 m beyond the magnet, what will the separation between the two impact zones be on the film?
Sodium has total-angular momentum of J=1/2, contributed by the spin of an electron of the 3s subshell.
I understand that as the electrons enter the magnet, half of the electrons will experience spin-up or spin-down depending if s is positive or negative and thus, there are only two permitted magnetic moments which gives two impact zones on the photo film.
However, I am confused as to how to find the distance between the two impact zones based on the information given.
Any assistance is welcome!
Thanks!
The separation distance between the two impact zones is given by the formula: d = (\nabla B * l^2)/(2mv), where m is the mass of the Sodium atom, v is its velocity, l is the length of the magnet, and \nablaB is the field gradient of the magnet. Using the given values for each of these parameters, we have: d = (9.0 T/m * 0.15m^2)/(2 * (22.98977 * 10-3 kg)*600m/s) = 0.0047m. Therefore, the separation distance between the two impact zones on the photographic plate is 0.0047m.
Based on the information provided, we can calculate the magnetic moment of Sodium atoms using the total-angular momentum and the Bohr magneton. The magnetic moment is given by μ = JgμB, where J is the total-angular momentum, g is the Lande g-factor, and μB is the Bohr magneton.
For Sodium, g = 2 and μB = 9.274 x 10^-24 J/T. Therefore, the magnetic moment of Sodium atoms is μ = 1/2 x 2 x 9.274 x 10^-24 J/T = 9.274 x 10^-24 J/T.
Next, we can use the equation for the deflection of a particle in a magnetic field to find the separation distance between the two impact zones on the photographic plate. This equation is given by d = μv/2B, where d is the separation distance, μ is the magnetic moment, v is the velocity of the particle, and B is the magnetic field gradient.
Substituting the given values, we get d = (9.274 x 10^-24 J/T)(600 m/s)/(2 x 9.0 T/m) = 3.09 x 10^-5 m.
Therefore, the separation distance between the two impact zones on the photographic plate will be approximately 3.09 x 10^-5 m. I hope this helps clarify your confusion.
Related to Stern-Gerlach Separation Distance on Target Film
1. What is the Stern-Gerlach Separation Distance on Target Film?
The Stern-Gerlach Separation Distance on Target Film refers to the distance between the target film and the Stern-Gerlach apparatus. This distance is crucial in determining the accuracy and precision of the separation of particles.
2. How is the Stern-Gerlach Separation Distance measured?
The Stern-Gerlach Separation Distance is typically measured using a ruler or caliper. The distance is measured from the center of the target film to the center of the Stern-Gerlach apparatus.
3. What is the significance of the Stern-Gerlach Separation Distance in scientific research?
The Stern-Gerlach Separation Distance is a critical factor in determining the accuracy of experimental results and the reliability of data. It allows researchers to control the distance between the particles and the target film, which can affect the trajectory and behavior of the particles.
4. How does the Stern-Gerlach Separation Distance affect the outcome of an experiment?
The Stern-Gerlach Separation Distance plays a crucial role in the outcome of an experiment. A shorter distance can result in a stronger interaction between the particles and the target film, leading to a more significant deflection. A longer distance may result in weaker interactions and less deflection.
5. Can the Stern-Gerlach Separation Distance be adjusted during an experiment?
Yes, the Stern-Gerlach Separation Distance can be adjusted during an experiment to achieve different separation results. However, it is essential to maintain a consistent distance to ensure accurate and reliable data. Adjusting the distance may also affect other variables, such as the strength of the magnetic field or the size of the particles.
