Stiffening Rings for pressure vessels
In summary, stiffening rings may be useful design features on a pressure vessel for reasons such as spreading local stresses at mounting points and pipe connections, but they do not provide additional protection against buckling modes caused by internal pressure. Structures typically buckle due to compressive principal stresses, so vessels under internal pressure do not require additional protection against buckling.
rollingstein
To guard against buckling modes I know that circumferential stiffeners can strengthen a cylindrical vessel against external pressure / internal vacuum.
Question: Stiffer rings do not contribute anything to protect vessel against internal pressure, correct? I think not, based on Stress eqs. and my understanding. But just wanted to verify my understanding.
As a general rule, structures buckle because the stress field has at least one principal stress in compression not in tension, so you don't need any "protection" against buckling for a vessel with internal pressure.
Stiffening rings may be useful design features on a pressure vessel for other reasons, of course - for example to "spread" the local stresses at mounting points, pipe connections, etc.
Likes 1 person
Thanks! That makes sense.
Related to Stiffening Rings for pressure vessels
What are stiffening rings for pressure vessels?
Stiffening rings are structural components that are added to the shell of a pressure vessel to increase its strength and stability. They are typically made of steel and are welded to the vessel's shell at regular intervals.
Why are stiffening rings necessary for pressure vessels?
Pressure vessels are designed to hold high levels of internal pressure, and without stiffening rings, the shell of the vessel may buckle or deform under this pressure. Stiffening rings help to distribute the pressure more evenly and prevent these deformations.
What factors determine the placement of stiffening rings?
The placement of stiffening rings is determined by the size and shape of the pressure vessel, as well as the operating conditions and the material being stored inside. Generally, they are placed at locations where the stress on the vessel is highest.
How are stiffening rings designed for pressure vessels?
The design of stiffening rings involves complex calculations and analysis, taking into account the vessel's dimensions, material, and operating conditions. Computer-aided design (CAD) software is often used to assist in the design process.
What are some common types of stiffening rings for pressure vessels?
The most common types of stiffening rings are horizontal rings, vertical rings, and girth rings. Horizontal rings are placed around the circumference of the vessel, while vertical rings are placed along the height of the vessel. Girth rings are placed at the ends of the vessel to provide additional support.
  • Mechanical Engineering
12K
