Still something wrong with server?
  • Thread starter Borek
In summary, the latest issue is that some RSS feeds are not fetching correctly, and this is causing some subpar performance. There is not much that can be done about it at this point, but it is good to know.
Borek
Mentor
29,068
4,440
For about last 10 minutes I wasn't able to access forums. Could be something local to me.
It's not just you, Borek. I'm having problems too.
Sorry, next time I will try to not see anything :-p
I've been experiencing the same problems since the switch.
I've noticed a few slow responses, but that could have been my ISP. But none today.
The failed drive was still attached. We had to take the server offline for a few minutes last night to get it out. Nothing else is being reported in any logs.
I have had some dead zones of 5-10 minutes today, though Yahoo and Google pop up instantly. Not a huge deal, but there may be something still lurking out there. Of course, re-routing due to floods in the NE might have pushed me through some heavily throttled trunks. There is a LOT of stuff that's not working real well here.
Must be all the high res photos of evo we've been uploading :-p
Now! More! More!
11:36 PM (Pacific Time) - Experiencing subpar performance and then received the following output after about a 30 sec delay:
Warning: MagpieRSS: Failed to fetch https://www.physicsforums.com/magpierss/cache/physorg175.xml.cache (HTTP Error: connection failed (11) in [path]/magpierss/rss_fetch.inc on line 238
Warning: array_slice() expects parameter 1 to be array, null given in [path]/includes/class_postbit.php(265) : eval()'d code on line 17
Warning: Invalid argument supplied for foreach() in [path]/includes/class_postbit.php(265) : eval()'d code on line 18
Warning: array_slice() expects parameter 1 to be array, null given in [path]/includes/class_postbit.php(265) : eval()'d code on line 24
Warning: Invalid argument supplied for foreach() in [path]/includes/class_postbit.php(265) : eval()'d code on line 25
I recall Greg once told us this is effect of some RSS feed (SciAm?) timing out and other errors are just a side effect. Problem lies outside PF server, so there is not much that can be done about it (that is, this particular RSS feed could be removed, but Greg wants it on the PF).
But I can be wrong.
Good to know. Thanks, Borek. :smile:
FAQ: Still something wrong with server?
What could be causing the server to malfunction?
There could be various reasons for the server to malfunction, such as hardware failures, software errors, network issues, or high traffic load. It is important to troubleshoot and identify the specific cause in order to resolve the issue.
How can I check if the server is down?
You can check if the server is down by trying to access the website or service hosted on it. If you are unable to access it, you can use a ping or traceroute tool to see if the server is responding. Additionally, you can check with your web hosting provider or IT team to see if there are any known issues with the server.
How can I fix the server if it is still not working?
If the server is still not working after troubleshooting, you can try restarting it or contacting your web hosting provider or IT team for further assistance. It is also important to regularly update the server's software and hardware to prevent future issues.
Can high traffic cause the server to malfunction?
Yes, high traffic can cause the server to malfunction if it is not equipped to handle a large number of requests. This can result in slow loading times, errors, or even crashes. It is important to regularly monitor and upgrade the server's capacity to handle high traffic.
How can I prevent server malfunctions in the future?
To prevent server malfunctions in the future, it is important to regularly maintain and update the server's hardware and software. It is also recommended to have a backup server or a failover system in place to ensure continuity of service in case of any issues. Regularly monitoring the server's performance and addressing any issues proactively can also help prevent future malfunctions.
