Stochastic Process, Poisson Process
In summary, we discussed the concepts of Poisson processes and binomial tests and used formulas to calculate the expected number of passengers waiting for the next bus, the expected and variance of the time until failure of a machine, and the expected time of failure given the number of shocks experienced.
Synthemesc90
Hi, I need some help with this hw
1. Suppose that the passengers of a bus line arrive according to a Poisson process Nt with a rate of λ = 1 / 4 per minute. A bus left at time t = 0 while waiting passengers. Let T be the arrival time of the next bus. Then the number of passengers who are waiting for is NT. Suppose that T is random with uniform density in the range (9, 11), T ^ U (9,11), and also Nt and T are independent.
a) Find E (NT | T)
b) Find E (NT), Var (NT)
In PP E(Nt)=Var(Nt)=λt
2. A machine is subjected to shocks that occur according to Poisson process Nt with rate λ . The machine can suffer a failure due to one of these shocks, and the probability of a crash caused the fault is p, regardless of the number of previous shocks (shocks form a sequence of binomial test). Denote by K the total number of shocks experienced by the machine before going down, and let T be the time when the fault occurs.
a) Find E (T), Var (T).
b) Find E (T | K).
Hi there! I would be happy to help you with your homework. I specialize in analyzing and interpreting data, so I am familiar with the concepts of Poisson processes and binomial tests.
To answer your first question, we can use the formula E(Nt) = Var(Nt) = λt, where λ is the rate of arrivals and t is the time interval. In this case, we know that λ = 1/4 per minute, so E(NT) = Var(NT) = (1/4)(10) = 2.5. This means that on average, there will be 2.5 passengers waiting for the next bus.
For part a), we need to find E(NT | T), which is the expected number of passengers waiting given the arrival time of the next bus. Since Nt and T are independent, we can use the formula E(NT | T) = E(NT) = 2.5.
Moving on to the second question, we can use the formula E(T) = 1/λ and Var(T) = 1/λ^2 to find the expected and variance of T. So, E(T) = 1/λ = 4 minutes and Var(T) = 1/λ^2 = 16 minutes^2.
For part b), we need to find E(T | K), which is the expected time of failure given the number of shocks experienced. Since the probability of failure is p regardless of the number of shocks, we can use the formula E(T | K) = E(T) = 4 minutes.
I hope this helps you with your homework. Let me know if you have any further questions or need clarification on any of the concepts. Good luck!
Related to Stochastic Process, Poisson Process
1. What is a Stochastic Process?
A Stochastic Process is a mathematical model that describes the evolution of a system over time in a random or probabilistic manner. It is used to study and understand the behavior of complex systems that are subject to randomness or uncertainty.
2. What is a Poisson Process?
A Poisson Process is a type of Stochastic Process that models the occurrence of events over a given time interval. It assumes that events occur independently of each other, and the time between events is exponentially distributed. It is commonly used to model phenomena such as arrivals in a queue, radioactive decay, or customer arrivals in a store.
3. How is a Stochastic Process different from a Deterministic Process?
A Stochastic Process involves randomness or uncertainty, while a Deterministic Process does not. In a Stochastic Process, the future state of the system cannot be predicted with certainty, while in a Deterministic Process, the future state is determined entirely by the initial conditions and the rules governing the system.
4. What are some applications of Stochastic Processes?
Stochastic Processes have a wide range of applications in various fields, such as finance, engineering, physics, and biology. They are used to model and analyze complex systems, make predictions, and understand the behavior of random phenomena.
5. How is a Poisson Process related to the Poisson Distribution?
The Poisson Process is closely related to the Poisson Distribution, which is a probability distribution that describes the number of events that occur in a fixed time interval. The Poisson Distribution is used to calculate the probability of a certain number of events occurring in a Poisson Process within a given time frame.
