MHB Stochastic Taylor's Expansion (Ito Rule)
The discussion centers on finding the Taylor expansion of the exponential function $e^{-\int_0^t k(s) dW_s}$, where $k(s)$ is a continuous function and $W_t$ is standard Brownian motion. The user successfully computed the expansion for the case of a constant $k$ as $e^{-k W_t} = 1 - k\int_0^t e^{-kW_s}dW_s + \frac{1}{2}k^2\int_0^t e^{-kW_s}ds$. However, they seek assistance with the more complex case involving a nonconstant function $k(s)$. A response suggests using a stochastic integral approach and applying a formula for analytic functions around $x=0$. The conversation emphasizes the challenge of extending known results to nonconstant scenarios in stochastic calculus.
gnob
Good day.
For $k\geq0$ a continuous function on $\mathbb{R}_+$ and $\{W_t\}$ a standard Brownian motion, could you help me find the Taylor's expansion of the following exponential: $e^{-\int_0^t k(s) dW_s}.$
For the case where $e^{-k W_t}$ where $k>0$ is a constant, I was able to recompute its Taylor's expansion as
e^{-k W_t} = 1 - k\int_0^t e^{-kW_s}dW_s + \frac{1}{2}k^2\int_0^t e^{-kW_s}ds.
But in the first exponential above, we have an integral exponent with a nonconstant $k,$ but a function. Please help me on this.
Thanks a lot in advance.
gnob said:
Good day.
Honestly I'm not sure to give the correct answer to the question but if we consider a stochastic integral like...
$\displaystyle \int_{0}^{t} f \{W(s)\}\ d W(s)\ (1)$
... if f(x) is analytic around x=0, i.e. is...
$\displaystyle f \{W(s)\} = \sum_{n=0}^{\infty} a_{n}\ W^{n} (s)\ (2)$
... then the following formula can be applied...
$\displaystyle \int_{0}^{t} W^{n}(s)\ d W (s) = \frac{1}{n+1}\ W^{n+1} (t) - \frac{n}{2}\ \int_{0}^{t} W^{n-1} (s)\ d s\ (3)$
Kind regards
$\chi$ $\sigma$
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
