Stoichiometry to find concentration and pH
That's bad. We don't know the pH is that accurate, and we don't want to assume it is.In summary, the concentration of OH- ions in the solution is 0.477 M and the pH is 13.259.
pleace
15.1g of calcium hydroxide completely dissociates in distilled water forming 855ml of basic
solution.
a) Dissociation Equation
b) Calculate the concentration of OH in the solution
c)Calculate the pH of the above solution
c=n/v
pH=-log[H]
a) Ca(OH)2 (s) = Ca2+ + 2OH -
i think that equation is right?
b) using molar mass ofCa(OH)2 and 15.1g, the moles of Ca(OH)2 is around 0.2moles.
since Ca(OH)2 and OH are in 1:2 ratio, then there is 0.4 moles Oh.
c=n/v
c=0.4/0.855 =0.452 mol/L(DO i use 0.855L for the volume even tho that includes the entire basic solution which is Ca2+ + 2OH - ?)
c) Now this is the part where i am really unsure about.
pH = -log[H], but since i want to find the entire solution's pH, what concentration do u use? do i divide 0.452/2=0.226
and then go -log0.226 = 0.64.
Thank you so much if you try to help me :)
The volume is 0.855 mL as per the question. Are you sure it's 0.855 mL in the question? I seem to get some weird answers if i use 0.855 mL. But, i will check out again.
We do not have the concentration of H+. Do you know any relation between p[H] and p[OH]? :wink:
i meant to put [OH] i forgot to type the O. and yes i am 100% sure that it says 855ml
Hi pleace! :smile:
No, you are halving the actual concentration that way...you need to pH of the solution which is defined to be the concentration of H+ in the solution. So use it to find pOH and then convert it to pH.
I misread the question, its 855 mL and i am seeing it as 0.855 mL, i am such a dumb. :-p
Anyways, back to question, do you know about the relation: p(OH)+p(H)=14?
Find pOH and use the relation to find pH.
solution.
c=n/v
pH=-log[H]
c=n/v
A is right, and B is right too. Concentration should be measured in molarity which you correctly represented as moles/liters. But don't round your sig figs so early, this could be bad.
1. Calculate the molar mass: this is about 74.0932 g/mol.
2. Multiply that by your 15.1 grams to get 0.2037973 mol.
3. Multiply that by two to get 0.4075946 mol.
4. Divide by .855 L to get a 0.476719 M solution of hydroxide OH- ions. But to get the right answer for C, you must take into account that we only have 3 sig figs, so the concentration would be 0.477 M.
5. Employ the rule pH + pOH = 14. In other words, pH = 14 - pOH. pOH = -log[OH-]. Our concentration is 0.476719 M, so we just take the negative log of that. -log[0.476719] = 0.740828. Therefore, pH = 14 - 0.740828 = 13.259172.
6. LAST STEP: Sig figs. The equation you gave us has two numbers: 855mL, and 15.1g. They both contain three sig figs. But when we use logs, the only sig figs are the ones to the right of the decimal. So 13.259172 pH becomes 13.259 pH.
EDIT:
This is why sig figs are so important. If we used your numbers, we would get a concentration of about 0.452 M, the total pH would be 13.655 instead of 13.259. That's about 0.396 off.
FAQ: Stoichiometry to find concentration and pH
1. How do you calculate concentration using stoichiometry?
In order to calculate concentration using stoichiometry, you will need to know the number of moles of the substance in question and the volume of the solution. Simply divide the number of moles by the volume to obtain the concentration in moles per liter (M).
2. Can you explain the relationship between concentration and pH?
Concentration and pH have an inverse relationship. This means that as the concentration of a substance increases, the pH decreases. This is because pH is a measure of the hydrogen ion concentration in a solution, and more concentrated solutions have a higher concentration of hydrogen ions, resulting in a lower pH.
3. How do you use stoichiometry to find the pH of a solution?
To find the pH of a solution using stoichiometry, you will need to first determine the concentration of the acid or base in the solution. Then, use the known equilibrium constant (Ka or Kb) for the acid or base to calculate the concentration of hydrogen ions (H+) or hydroxide ions (OH-). Finally, use the pH equation (pH = -log[H+]) to find the pH of the solution.
4. What is the relationship between stoichiometry and the concentration of a solution?
Stoichiometry is used to determine the amount of reactants and products in a chemical reaction. This information can then be used to calculate the concentration of a solution. By knowing the number of moles of a substance involved in a reaction and the volume of the solution, we can use stoichiometry to find the concentration of the solution.
5. Can you use stoichiometry to find the concentration of a gas in a solution?
Yes, stoichiometry can be used to find the concentration of a gas in a solution. The concentration of a gas in a solution is typically expressed in units of moles per liter (M). By using stoichiometry to determine the number of moles of the gas and the volume of the solution, we can calculate the concentration of the gas in the solution.
