Stokes' Theorem parameterization
In summary: The unit normal vector is easy to find. You can just use the parametrization of the circle to find it.
  • #36
reminiscent said:
So would it be <0,0,sqrt(2)>?
Do I have to use polar coordinates?
This is getting a bit silly. Do you really have to ask whether <0,0,sqrt(2)> is a unit vector?
And before you talk about polar coordinates or rectangular coordinates, let's see what your integrand is. In post #15 we called the ##\vec V## the curl of ##\vec F## and the integrand is ##\vec V\cdot d\vec S##. What does that work out to?
<h2>1. What is Stokes' Theorem parameterization?</h2><p>Stokes' Theorem parameterization is a mathematical tool used to evaluate line integrals over a closed curve in a three-dimensional space. It relates a surface integral to a line integral by using a vector field and a differential form.</p><h2>2. How is Stokes' Theorem parameterization used in scientific research?</h2><p>Stokes' Theorem parameterization is commonly used in physics, engineering, and other scientific fields to calculate the circulation of a vector field around a closed curve. It is also used to evaluate flux integrals over a surface and to solve problems involving conservative vector fields.</p><h2>3. What are the conditions for applying Stokes' Theorem parameterization?</h2><p>In order to apply Stokes' Theorem parameterization, the surface must be smooth and orientable, and the vector field must be continuous and differentiable on the surface. The curve must also be a closed curve that lies on the boundary of the surface.</p><h2>4. How is Stokes' Theorem parameterization related to Green's Theorem?</h2><p>Stokes' Theorem parameterization is a higher-dimensional version of Green's Theorem, which relates a line integral to a double integral over a region in the plane. Green's Theorem can be seen as a special case of Stokes' Theorem parameterization when the surface is a flat plane.</p><h2>5. What are the practical applications of Stokes' Theorem parameterization?</h2><p>Stokes' Theorem parameterization has many practical applications, including calculating the work done by a force field on a particle moving along a closed path, determining the flow of a fluid around a closed loop, and finding the total electric charge enclosed by a closed surface. It is also used in the study of fluid dynamics, electromagnetism, and other areas of physics and engineering.</p>
FAQ: Stokes' Theorem parameterization
