Stopping distance of a car rolling down a hill
In summary, the Homework Statement asks if the mass of a car affects the distance it travels before stopping. The result shows that the mass does not affect the distance traveled before stopping, however the rolling resistance does.
Barnt
Hello,
This is an investigation I have been studying recently, can someone help with the following...
1. Homework Statement
Method:
1. Place a toy car at the top of a ramp.
2. Let it go.
3. Measure the distance it travels from the bottom of the ramp.
4. Add a 100 g mass to the car and repeat.
5. Repeat with additional masses attached.
I expect the car with more mass to travel further. However, the results show very little variation
This is what I have been thinking...
GPE = KE
Therefore, the masses cancel, therefore each of the cars have the same velocity at the end of the ramp.
The car with the most mass has the most KE. Therefore , more Work is needed to change the cars velocity to zero. Therefore, the car with the most mass should travel the furthest before stopping.
[/B]
I was thinking, the normal force is equal to the car's weight. When the car's weight increases, the normal force increases. The normal force is the force that is doing the work to stop the car. Since the normal force increases when the weight increases, enough work is done to slow the car down.
Equation:
ma = µR
ma = µmg
However, I understand this would only apply to a block sliding down a ramp, not a car with rotating wheels.
Do my results make sense? Should the mass cause the distance traveled by the car to increase?
Thanks in advance for your assistance.
That needs an additional assumption about the motion (but the result is right).
Where does the work to stop the car come from? Is that the same for both cars?
It is not. It is normal to the motion of the car (on the horizontal part), it cannot do work. It leads to something else that does work, however.
A car with wheels has rolling resistance, within the scope of this question it is very similar to sliding friction.
So, friction is doing the work to stop the car. Friction force = µR. So, ma = µmg. Meaning if the weight increases the friction force increases too, so the mass will not affect the distance traveled by the car before stopping. So, the KE increases with mass but so does the friction force.
Right.
This true while on the ramp already.
If drag becomes important then the situation gets more complicated.
To clarify, as mfb indicated, it is a matter of rolling resistance, not friction.
The wheels rotate, so the friction between the wheels and ground is static friction. Static friction does not do work because the points in contact do not move relative to each other.
Rolling resistance is a bit more complicated. In general, it is made up of three different things:
- imperfectly elastic deformation of the wheels
- imperfectlly elastic deformation of the ground
- axial friction
Axial friction is proportional to load, just like regular planar kinetic friction, so leads to the same result. Losses from deformation can rise faster than linearly, though, so a greater mass could lead to less distance.
Related to Stopping distance of a car rolling down a hill
1. What factors affect the stopping distance of a car rolling down a hill?
The stopping distance of a car rolling down a hill is affected by several factors, including the incline of the hill, the weight and speed of the car, the condition of the brakes, and the type of surface the car is traveling on. The steeper the incline, the longer the stopping distance will be. A heavier car will also require a longer stopping distance, as will a car traveling at a higher speed. Worn or faulty brakes can also increase the stopping distance, as can a slippery or uneven surface.
2. How does the speed of the car affect the stopping distance?
The speed of the car has a significant impact on the stopping distance. The faster the car is traveling, the longer it will take to come to a complete stop. This is because the car has more kinetic energy at higher speeds, and it takes longer for that energy to be dissipated through braking. As a general rule, doubling the speed of a car will quadruple the stopping distance.
3. Can the stopping distance of a car rolling down a hill be calculated?
Yes, the stopping distance of a car rolling down a hill can be calculated using the following formula: stopping distance = (initial velocity^2) / (2 * deceleration). The initial velocity is the speed of the car at the top of the hill, and the deceleration is the rate at which the car slows down due to friction and braking. Keep in mind that this calculation is an estimate and may not account for all factors that can affect the stopping distance.
4. How can the stopping distance of a car rolling down a hill be reduced?
The stopping distance of a car rolling down a hill can be reduced by ensuring that the brakes are in good working condition and by driving at a safe speed for the conditions. In addition, using low gears and engine braking can help to slow the car down more quickly. It is also important to keep a safe distance from other vehicles and objects to allow for enough time to stop.
5. Why is it important to consider the stopping distance of a car rolling down a hill?
Understanding the stopping distance of a car rolling down a hill is crucial for ensuring the safety of both the driver and others on the road. It can help drivers make informed decisions about their speed and braking, and can also be useful in emergency situations. By considering the factors that affect stopping distance, drivers can take appropriate precautions to reduce the risk of accidents and collisions.
