Stopping in min. distance[friction]
  • Thread starter vissh
In summary, when trying to stop a car on a horizontal road, one should apply the brakes hard enough to just prevent slipping. This is because the friction force slowing down the car is predominantly the static friction force, which is greater than the kinetic force while sliding. When a car is accelerating, the friction on the driving wheels is forward, but on the other wheels it is backward. On braking, the friction force on the braked wheels is backward, causing the car to decelerate. This is caused by a friction force from the chassis on the wheels, slowing the rotation and causing the wheels to exert a friction force forward on the road. The friction on the road is in the opposite direction of motion, while the friction on the tyre
vissh
82
(Q)In order to stop a car in shortest distance on a horizontal road, one should :-
<a>apply the brakes very hard so that the wheels stop rotating
<b>apply the brakes hard enough to just prevent slipping
<c>pump the brakes
<d>shut the engine off and not apply brakes
When a body slips on a surface & the body and surface are rough,the kinetic friction start to act.
I think <a> is correct as if the wheels start to slip the kinetic friction will act on car which is > or = to frictional force in other cases and also in <a> this friction will act continuosly.
But the answer in book is <b> oO. [I think in <b> ,rolling friction will act which is less than kinetic friction]
Can anyone guide me :)
Thanks in advance ^.^
Well, there's a little bit of rolling friction in there, usually very small and much less than the kinetic friction force. Predominantly, the friction force slowing down the car is the static friction force, which is greater than the kinetic force while sliding, and which occurs as long as the wheels are still rotating, maximized just before slipping occurs.
hi vissh! :smile:
no, it's best not to talk about rolling https://www.physicsforums.com/library.php?do=view_item&itemid=39"
there are two types of friction: kinetic and static …
when a wheel slides, that's kinetic friction; when a wheel rolls, that's static friction …
in both cases there is also a very small loss of energy (due mostly to deformation of the wheel and tyre), which it is better to call rolling resistance
(b) was correct because static friction is larger than kinetic friction :wink:
Thanks both of you ^.^
Got a thing to ask :- When the brakes are applied and the wheel just rolls on road[no slipping], does this "braking" gives the point of contact a tendency to move in direction of original motion Due to which the static friction acts on the opposite direction of motion [And thus,the body slows down]? oO
hi vissh! :smile:
sort of …
the whole friction-on-rolling-wheels thing is rather perplexing …
when a car is accelerating, the friction on the driving wheels (from the road) is forward, but the friction on the other wheels (from the road) is backward! :rolleyes:
and yes, on braking, the friction force on the braked wheels (from the road) is backward, causing the car to decelerate
this is caused by a friction force from (essentially) the chassis on the wheels, slowing the rotation, and causing the wheels to exert a friction force forward on the road: the equal backward reaction force from the road on the wheels decelerates the car :smile:
to find the direction of friction, always ask "what would happen if there was no friction?" (for example, if one surface was ice) …
if the car is braking (on ice), the braked tyre will go slower, but the car will stay the same speed (because there are no forces on it): looking down from the window, you see the road going backward faster than the tyre is going backward, so the road is going faster backward than the tyre, and it will try to drag the tyre with it
in other words: the tendency is for the road to move backward relative to the tyre, so the friction on the road is forward, and the friction on the tyre is backward
however, the non-braked tyres (usually the front, steering, tyres) will have a forward friction force from the road at the same time …
if the car is braking, and if the non-braked tyres only are on ice, the non-braked tyre will go at the same speed, but the car will go slower: looking down from the window, you see the road going backward slower than the tyre is going backward, so the road is going slower backward than the tyre, and it will try to drag the tyre with it
in other words: the tendency is for the road to move forward relative to the tyre, so the friction on the road is backward, and the friction on the tyre is forward
this of course is why 4-wheel braking slows a car faster than 2-wheel!​
by comparison:
if the car is accelerating (on ice), the non-driving tyre will stay the same speed (because there are no forces on it), but the car will go faster: looking down from the back window, you see the road going backward faster than the tyre is going backward, so the road is going faster backward than the tyre, so it will try to drag the tyre with it
But if the car is accelerating (on ice), the driving tyre will go faster (because the engine is puling it … the lack of friction doesn't matter), but the car will stay the same speed (because there are no forces on it): looking down from the back window, you see the road going backward slower than the tyre is going backward, so the road is going faster forward than the tyre, so it will try to drag the tyre with it
in other words: the tendency is for the road to move forward relative to the tyre, so the friction on the road is backward, and the friction on the tyre is forward!
Thanks Thanks a lot tim :D
Really appreciate your help ^.^
Related to Stopping in min. distance[friction]
1. What is stopping distance?
Stopping distance is the total distance that a vehicle travels from the moment the brakes are applied until it comes to a complete stop. It includes both the distance covered while the driver reacts to a situation and the distance the vehicle travels while braking.
2. What factors affect stopping distance?
The main factors that affect stopping distance are the speed of the vehicle, the condition of the road surface, and the condition of the vehicle's tires and brakes. Other factors such as weather conditions and the weight of the vehicle can also play a role.
3. How does friction affect stopping distance?
Friction is the force that resists the motion of two surfaces in contact with each other. In terms of stopping distance, friction between the tires of a vehicle and the road surface is crucial. The more friction there is, the faster the vehicle will stop. However, too much friction can cause the tires to lock up and skid, increasing stopping distance.
4. How can we calculate stopping distance due to friction?
To calculate stopping distance due to friction, we can use the following equation: stopping distance = initial velocity² / 2 x acceleration x coefficient of friction. The coefficient of friction is a measure of how much friction there is between two surfaces and can be found for different road conditions.
5. How can we reduce stopping distance due to friction?
To reduce stopping distance due to friction, we can ensure that our vehicle is well-maintained with good tires and brakes. We can also drive at a safe speed and pay attention to road conditions. In emergency situations, it is important to avoid slamming on the brakes and instead apply steady pressure to avoid skidding and increase friction between the tires and the road.
