emilmammadzada
- 109
- 18
The title of the example of "Charged pion fluence inside and around a proton-irradiated Be target"emilmammadzada said:TL;DR Summary: Stopping power and projected range for fluka code
How do I calculate the stopping power or projected range for aluminum in Fulka. And in which output file is this data located?How can I edit a change in the input file?
Stopping power in FLUKA simulations refers to the ability of a material to slow down charged particles, primarily through interactions that result in energy loss. It is a critical parameter for understanding how particles lose energy as they traverse different materials.
To calculate the stopping power using FLUKA, you need to set up a simulation that includes the material of interest and the particle type and energy. FLUKA provides built-in routines and scoring options, such as the USRTRACK and USRBIN cards, to evaluate energy deposition and stopping power along the particle's path.
The projected range in FLUKA refers to the average distance a particle travels in a given material before coming to a stop. It is different from stopping power, which measures the rate of energy loss per unit distance. The projected range provides an overall estimate of how far a particle can penetrate a material.
To determine the projected range of a particle in a specific material using FLUKA, you can use the USRTRACK or USRBIN cards to track the particle's path and energy loss. By analyzing the output data, you can calculate the average distance traveled by the particle before it stops.
Yes, for accurate stopping power and range calculations in FLUKA, it is recommended to use the USRTRACK, USRBIN, and possibly the AUXSCORE cards. These allow for detailed scoring of energy deposition and particle tracking, which are essential for precise determination of stopping power and projected range.
