Stopping vertically oscillating mass by applying momentum?
In summary: This force is equal to the mass of the object (plus the mass of the object that has moved) times the speed of the object at the equilibrium position.
amiras
65
I came with this problem myself, so there may be not enough information given to solve it.
Imagine that mass M oscillating on the vertical spring with force constant k and amplitude A. Now let's say that the mass M is moving upward. Now imagine that some other object with mass m having speed v_m comes from the sky and collides with the oscillating mass and after collision sticks to it.
Is it possible stop the mass M from oscillation? What position? What velocity of v_m?
Can I apply conservation of momentum at every displacement of the spring assuming it happen in short time?
Applying it at equilibrium position would give: v_s*M - v_m*m = 0, where v_s is the speed of the mass M. But does the final momentum equal to zero means that both bodies stuck and do not move or that they exchanged momentum and still moving to opposite directions?
It depends on what you mean by "stop the mass M from oscillation".
It is possible to arrange the things so that after collision the two bodies have zero velocity.
However, unless this happens right in the equilibrium position (new one, with the extra body attached), the oscillations will start again. So you only stop it for an instant and then it restarts, with a different amplitude and period.
Yes that is exactly what I wanted.
Ok so imagine that d2 = (m+M)g/k is the new equilibrium position for the system.
After the collision the body must move just as much to stretch spring from current equilibrium position to the new. In other words all the left kinetic energy after collision must be used to stretch extra distance.
Initially spring stretched d1 = mg/k. So using 1/2(m+M)v^2 = 1/2k((d2)^2 - (d1)^2) Would give the right speed after collision.
Now we want after collision masses will move with this velocity v, so using conservation of momentum:
m*v_e + M*v_s = v(m+M), where v_e the speed of mass m, and v_s speed of mass M.
From here it is possible to calculate v_e what I wanted initially.
Is that OK?
You don't need any kinetic energy to stretch spring from current position to the new equilibrium. If after collision the system is not in the equilibrium position, there will be some force acting towards the equilibrium position (the net force is zero at equilibrium, by definition).
I would first clarify the question and gather more information to fully understand the scenario. Some questions I would ask are: What is the initial position and velocity of the oscillating mass M? What is the initial position and velocity of the object with mass m? Is there any external force acting on the system?
Assuming that there is no external force and the initial position and velocity of both masses are known, we can use conservation of momentum to determine the final velocity of the masses after collision. However, it is important to note that in a real-world scenario, there will be some energy loss due to friction and other factors, so the final outcome may not be exactly as predicted by calculations.
If the final momentum is zero, it means that the masses are stuck together and not moving. If the final momentum is non-zero, it means that the masses are still moving in opposite directions, but their combined momentum is equal to the initial momentum of the system. The exact position and velocity of the masses after collision will depend on the specific values of the masses and velocities involved.
In summary, it is possible to stop the oscillation of mass M by applying momentum, but the exact outcome will depend on the initial conditions and any external forces acting on the system.
FAQ: Stopping vertically oscillating mass by applying momentum?
How does momentum affect vertical oscillation?
Momentum is a measure of an object's mass and velocity. In the context of vertical oscillation, applying momentum can help stop the movement of a mass by counteracting its velocity and decreasing its kinetic energy.
What are the factors that influence the effectiveness of applying momentum to stop vertical oscillation?
The effectiveness of applying momentum to stop vertical oscillation depends on the mass and velocity of the object, as well as the force applied. The greater the mass and velocity, the more momentum is needed to stop the oscillation. Additionally, the force applied must be in the opposite direction of the object's motion.
Can vertical oscillation be completely stopped by applying momentum?
In theory, yes, vertical oscillation can be completely stopped by applying enough momentum to counteract the object's motion. However, in practical applications, there may be factors such as friction and air resistance that can impede the effectiveness of applying momentum.
Is there a limit to how much momentum can be applied to stop vertical oscillation?
There is no limit to the amount of momentum that can be applied to stop vertical oscillation, as long as there is a force acting in the opposite direction of the object's motion. However, there may be practical limitations, such as the strength of materials used to apply the force.
How is the conservation of momentum related to stopping vertical oscillation?
The conservation of momentum states that in a closed system, the total momentum before an event is equal to the total momentum after the event. In the case of stopping vertical oscillation, the application of momentum is the event that changes the momentum of the object in motion, and the conservation of momentum ensures that the total momentum of the system remains constant.
