Store wood in old salt mines to reduce CO2 in the atmosphere
In summary, storing trees in salt mines does not reduce CO2 levels in the atmosphere. And if trees are left in the forest and then rot 90% of their mass also go back into the atmosphere.
somega
32
If trees are cut and then burned they have not reduced the CO2 in the atmosphere at all.
And if they are left in the forest and then rot 90% of their mass also go back into the atmosphere.
Here in Germany we have many old salt mines.
I wonder if it would be a good idea to cut trees and store them in the salt mines.
The salt mines could then be flooded with seawater and sealed (so they don't rot).
Would this be realizable?
that renders them unstable: a liter of seawater dissolves some 0.3 kg of salt ...
To the tune of how much energy per ton of CO2 stored 'forever' ?
Why not just plant a new tree??....seems simpler.
Likes davenn
It is often difficult to make beginners understand that (old) forests does not really make oxygen // consume CO2. They just circulate it, through the sum of the biomass belonging to the forest. With removing too much wood this circulation stops and the forest dies. That 'rotting' process is needed to keep the forest going on.
Only young forests consuming CO2 while they are growing up towards their stable biomass amount.
I would propose something different and maybe: disturbing. Germany exports hundred thousand tons of plastic waste to the far east for recycling, https://www.handelsblatt.com/today/politics/the-plastic-trail-how-germanys-recycling-ends-up-in-malaysian-dumps-/24037020.html: it is not too exaggerating to say that this has some contribution to the Pacific Ocean waste islands, since the target of this export is actually the states with highest release there.
That plastic waste contains carbon as well: instead of stuffing away perfectly good wood or exporting waste, you can safely suggest to store that up. It would also save the CO2 footprint of the transport.By the way, about a relatively freshly proposed alternative way for getting rid of that plastic: composting.
That's a lie. Plastic is mostly made from C and H. It has no useful contribution to compost, it just disappears and releases the C to the atmosphere as CO2 (actually it is already best case if it is just CO2).
Likes BvU
I think we're missing a trick here. 1st, as others have noted, old, rotting trees are essential for healthy forest metabolism, and as links in trophic chains feeding microbes, fungi, insects and their predators. They provide nest sites and habitat for salamanders. And as they convert to spongey mass, nurseries for future forest trees. So they're needed in those roles.
But if increasing the amount of carbon stored longterm from biomass is the objective, we need look no further than biochar. A long term carbon sequestration strategy which also feeds the soil, moderates moisture extremes and conserves nutrients, biochar is the missing 'trick' for German forest management and for countries globally. It's been ignored by too many people for too long, possibly because it is actually such a democratic technology that proponents of more high tech C capture solutions have no interest because they cannot also capture the massive subsidies directed their way for technologies they can patent and control. Same-old, same-old.
Likes Nik_2213, davenn and gleem
Elemental carbon is an extremely stable substance. The only issue in producing biochar might be what other products are produced that might be of concern and what would be the best energy source for the process?
Tons, I mean TONS of that has already been worked out over something like 20 years of testing and research by individuals and institutes around the world. Many of the other products have market value, so the economies of production are fairly strong.
Circular material strategies are important (and not just in biochar production) to capture all byproducts and not have them end up as pollution (biogas, bio oils, resins...all substrates for greener energy or greener manufacturing). Much depends on the type of kiln used, the temperature and pressure applied. It's adjustable to optimise for various qualities of char and the type and quality of byproducts.
At least some of the pyrolysis processes need very little additional energy inputs once they get started. They self-power.
The process does produce and release some CO2 though, yes? Do you have a reference that gives some hard accounting numbers for the carbon balance? Sounds very interesting.
Thank you for mentioning bio-char kindly. In addition to extensive sequestration of carbon, and improving land quality, plus easing heavy tillage, it would also serve to re-build soil depth.
One easy method is to move forestry away from slow growing boreal regions to more temperate regions where trees can be farmed and much more rapidly produced. You would not need to store trees in a salt mine, just use them to build permanent structures. Also farmland is shrinking in developed countries - technological improvements in productivity result in marginal farmland becoming uneconomic. Incentives could be provided to reforest these areas.
Likes davenn
As a matter of fact, hundreds of thousands of tons of "wood" is being stored in old salt mines in the USA. The wood is in the form of paper in file cabinets in deep storage.
  • Haha
Likes phinds
Old dutch expresssion: a drop on a hot plate
Use wood for buildings instead of concrete, whose manufacture is very energy intensive.
House of straw, house of sticks, house of bricks
Big bad wolves are hurricanes and earthquakes
Must concede wood is better in the latter...
By my humble opinion as long as there is coal mined, there is very little point in burying coal back down: especially with any effort (energy) spent on it.
You may need to explain this. Burying charcoal is a 100% offset of burning a fossil fuel. You just need to bury the right quantity and take action to reduce fossil fuel consumption so that a balance is obtainable in conjunction with other provisions.
The process of making charcoal oxidizes some carbon ; it's pretty much unavoidable. Not to say producer gas isn't really really interesting.
The problem is exactly this part, since it is not true. Mining coal consumes energy, so is to raise and prepare that wood: to deliver it to the site and to bury it. All that activity consumes energy, and that energy - by the actual stats - will come from other fossil fuel: mostly, at least.
So to completely balance the coal mined you need to bury more charcoal than the mined amount - but wouldn't it be better then, to use the charcoal directly and leave the coal down in the mine?
In general, all this kind of 'save the planet' actions are pretty much just a dead end. The right priority is to not ruin it in the first place.
Yes - you have to bury more charcoal to offset the same carbon released by fossil fuels and yes, it would be better to use charcoal directly to avoid extracting fossil fuel. You do not ruin the planet using wood, charcoal, wind, solar, or hydrogen.
This is not the point being considered. The point is that we need removal of current excess carbon that is already in the biosphere.
Did you read:
https://cbmjournal.biomedcentral.com/articles/10.1186/1750-0680-3-1
and
https://www.sciencedirect.com/science/article/pii/S0961953407000323?via=ihub
Burying carbon or maybe sinking it in the deep ocean seems a reasonable suggestion to remove excess carbon from the atmosphere.
We need to remove Carbon-dioxide, not Carbon. Elemental Carbon is pretty non-reactive : Do you see wooden structures evaporating ? Are there reports of pencils spontaneously combusting ?
Sequestering (as in "don't use it as fuel") carbon is a good idea, but it's not necessary to sink it into the ocean, or bury it in salt mines. Bit of a pain to retrieve if we ever need carbon in bulk.
Sorry, that makes no sense whatsoever to me. Are there words missing ?
Your comment was far too vague. It seems you have not read, or digested, previous comments in this thread.
Removing carbon via trees (or any form of flora) is removing CO2.
Something may seem reasonable in itself, but it can be seen as quite unreasonable when analysed as part of a total system. When your bath is overflowing, you can bail it with a small cup into a sink, or you can turn off the water flowing into the bath. The biggest problem is getting people to understand the bigger picture.
Your firm attachment to the simplistic idea of burying the problem is a form of denial, it is simply a distraction. It disguises the fact that the capacity to extract and bury carbon is infinitesimal when compared with the magnitude of fossil fuel extraction.
We need organic material in soil to manage water, so we can grow more plants. Any plant carbon that we place in deep storage is a waste of energy and effort. That carbon would have been better used in the soil, or to immediately reduce coal mining. Can you not see the double-handling inefficiency of mining coal while burying trees?
We need to manufacture durable essentials from wood with character, not from short-lived toxic plastics derived from fossil fuels. We need more surface vegetation to stabilise surface temperatures. Clearing that vegetation and burying it deep is an unnecessary and wasteful process that destroys the soil structure and creates deserts. Attempting to strip the surface of vegetation to counter historical and current fossil fuel extraction, demonstrates a failure to understand the magnitude of the imbalance in the system.
One quick test of reasonableness should be, “does the action reduce fossil fuel extraction now”?
Likes DrClaude and Rive
Once you accuse others of denial, you remove yourself from consideration.
You need to cite refereed sources before continuing any further.
We could always bury the short lived plastics and...oh right, that’s called a landfill.
You might want to qualify that in some respect : you're all for paving over woodlands ?
Likewise, your comments concerning charcoal are confusing.
Brilliant 😆
Where did that come from ?
What is the confusion ?
Did you read the source material?
^ You should really think about getting that ? thing fixed.
It came from the statement that I quoted. Your wording needs work, IMO.
On that note, regarding a previous post where I stated "We need to remove CO2, from the environment, not C", let me add "We need to sequester C, not CO2" for clarification.
__________________________
You gave two "source materials" for my edification.
Bury Trees: not an optimum solution. Waste of wood. Also, a waste of empty salt mines : there's an entire desalination industry waiting to spring up, that could use an appropriate place to store their leftovers.
Maybe we could do some social engineering such that desert countries build with wood imported from wet countries, instead of concrete and steel. Might as well do wood framed/panelled cars as well. According to an acquaintance, the former Soviet Union's otherwise-generally-reviled Trabants used a papier-mache composite for body panels.
Create Black Carbon From Biomass : I don't plan on purchasing a subscription to the site which hosts the paper, so I didn't read far enough to see
a) how they're going to create "black carbon" in the first place, nor
b) what they plan on doing with it.
I would tender that non-recycleable plastic would be a better candidate. At least until we can get our sh*t together and tax the hell out of companies that use same so they stop doing so.
I never mentioned paving nor woodlands. This was a fabrication.
Burying non-recycleable plastic, has the same effect, and so can be added in.
If you go to a local library, they probably will obtain the article for you.
Your other comments amount to little more than naive heckling. Given the seriousness of global warming I would have expected better.
  • #32
In the interest of rescuing this thread...yes, burying wood can be a form of carbon sequestration, as long as it’s buried in a way that prevents it from rotting (and thus releasing its carbon back into the atmosphere). This—albeit on a much slower timescale—is basically how fossil fuels came to exist in the first place. In addition, there’s plenty of waste wood from industrial lumber processes that could be a good candidate.
The problem isn’t the science; the problem is the economics. You can use waste wood for a number of things (including burning it for energy) that you can presumably sell at a profit (or at least mitigate a loss). Sending waste wood to a regular landfill will just allow it to decompose and release its carbon. So there would have to be a dedicated infrastructure for burial of wood. We have similar dedicated infrastructures for special waste streams—in particular, recycling centers and hazmat disposal centers—but in the first case, the end product can, at least in theory, be resold at a profit, and in the second case, there is a clear immediate danger to public health. With wood burial, neither of those apply, so there’s no economic incentive.
Which means that an incentive must be artificially supplied: then the issue becomes political. Probably the easiest way to incentivize carbon sequestration is through a carbon tax, and wood burial could be rolled into this as a specialized form of sequestration. If the legal framework allows it (e.g., carbon offset trading), you could conceivably see companies pop up that grow and bury a fast-growing plant like bamboo and sell the offsets at a profit to major polluters.
Likes Lord Jestocost
  • #33
There will come a time when the process of filling the mine with wood will become carbon neutral and economically optimum. Now is NOT that time.
Filling the mine now would be carbon inefficient. It would be better to delay the process until excess renewable (electric?) energy was available to power all the vehicles needed to transport and bury the material.
  • #34
Yes, the key is economics. You can cover costs using heat for any number of industrial purposes from producing charcoal. This by itself could keep some fossil fuels in the ground.
The benefits of charcoal (and also its stability) gives it a potential role in sequestration.
Economically, all we need to resource is the production and sequestration of 1 tonne of charcoal per person per year and less if we accelerate other renewables.
Most nations should be able to produce a 20kg bag of charcoal per week for each of their citizens. It would require some diversion of labour but nothing that has not occurred during wars. 20kg bags are already available in BBQ supply outlets.
A total rollout of electric and hydrogen powered vehicles, will make the task even easier.
  • #35
That's about multiplying the food production by three to fivefold, at the very least.
Not gonna' happen: not without excess carbon footprint increase with an even higher multiplier: not in any sustainable way: not in any economically acceptable way.
You have absolutely no idea what you are talking about.
<h2>1. How does storing wood in old salt mines reduce CO2 in the atmosphere?</h2><p>When wood is stored in old salt mines, it is effectively removed from the carbon cycle. This means that the carbon in the wood is not being released into the atmosphere as carbon dioxide through decomposition or burning. By keeping the carbon in the wood trapped underground, it helps to reduce the amount of CO2 in the atmosphere.</p><h2>2. Can any type of wood be stored in old salt mines?</h2><p>Yes, any type of wood can be stored in old salt mines. However, it is important to ensure that the wood is properly dried and treated to prevent decay and mold growth while in storage. This will help to maintain the integrity of the wood and prevent any potential release of CO2.</p><h2>3. How long can wood be stored in old salt mines?</h2><p>The length of time that wood can be stored in old salt mines varies depending on the type of wood and the conditions of the mine. Generally, wood can be stored for several decades without any significant degradation. However, it is important to regularly monitor the wood and make any necessary adjustments to ensure its long-term storage.</p><h2>4. Is storing wood in old salt mines a sustainable solution for reducing CO2?</h2><p>While storing wood in old salt mines can be an effective short-term solution for reducing CO2 in the atmosphere, it is not a sustainable long-term solution. Eventually, the stored wood will decompose or be released back into the atmosphere through human activities. Therefore, it is important to also focus on reducing carbon emissions and implementing more sustainable practices to combat climate change.</p><h2>5. Are there any potential drawbacks or risks to storing wood in old salt mines?</h2><p>There are some potential drawbacks and risks to storing wood in old salt mines. These include the possibility of the wood decaying or releasing methane gas, which is a potent greenhouse gas. Additionally, there may be challenges in finding suitable and accessible old salt mines for large-scale wood storage. It is important to carefully consider and assess these risks before implementing this solution on a larger scale.</p>
Related to Store wood in old salt mines to reduce CO2 in the atmosphere
