Stored charege and potentials of two capacitors in series
In summary, two capacitors of 2.0F and 5.0F connected in series and connected to a 1.5 volt battery have an equivalent capacitance of 1.429F. The charge stored on each capacitor is 2.143 and the potential difference across each capacitor is 1.072V and 0.429V respectively.
zoner7
90
Two capacitors of 2.0F and 5.0F are connected in series; the combination is connected to a 1.5 volt battery. What is the charge stored on each capacitor? What is the potential difference across each capacitor?
C = Q / (Delta)V
Since the capacitors are in series, we can find the equivalent capacitance by solving:
1/Ceq = 1/2.0F + 1/5.0F
Ceq = 1.429F
I then used this value to find the charge on each plate of each capacitor
C = Q/V
CV = Q
1.429F * 1.5V = 2.143
So now I now the amount of charge on each plate.
Using this value in conjunction with a specific capacitance, I can find the potential difference across any given capacitor whose capacitance I know.
so, V = Q/C
2.143/2 = 1.072V
2.143/5 = .429V
Thank you for the help.
All correct, I think. I used a slightly different method, adding the voltages around the loop to get Q/2 + Q/5 = 1.5
which yields the same answer you got.
It is important to note that the potential difference across each capacitor will be different, as it is dependent on the capacitance of each individual capacitor. The higher the capacitance, the lower the potential difference across the capacitor. Additionally, the charge stored on each capacitor will also be different, as it is dependent on the potential difference and the capacitance. It is important to carefully consider the values of capacitance and potential difference in a series circuit to accurately calculate the charge stored on each capacitor.
FAQ: Stored charege and potentials of two capacitors in series
What is the formula for calculating the equivalent capacitance of two capacitors in series?
The equivalent capacitance of two capacitors in series can be calculated using the formula 1/Ceq = 1/C1 + 1/C2, where C1 and C2 are the individual capacitances of the two capacitors.
How do the stored charges of two capacitors in series compare to each other?
In a series circuit, the same amount of charge is stored in each capacitor. This is because the capacitors are connected in a series, so the current flowing through them is the same.
What happens to the total potential difference when two capacitors are connected in series?
The total potential difference across two capacitors in series is equal to the sum of the individual potential differences across each capacitor. In other words, the potential differences add up.
Can the total capacitance of two capacitors in series be greater than the individual capacitances?
No, the total capacitance of capacitors in series will always be less than the individual capacitances. This is because they share the same charge, but the voltage (potential difference) is divided between them.
How does the equivalent capacitance of two capacitors in series affect the overall capacitance of a circuit?
The equivalent capacitance of two capacitors in series decreases the overall capacitance of a circuit. This is because the total capacitance is inversely proportional to the equivalent capacitance, so as the equivalent capacitance decreases, the total capacitance decreases as well.
