Straightforward limit problem =/
  • Thread starter Nano-Passion
  • Tags
    Limit
In summary, the question is asking for the limit as x approaches 0 of sin x/x. The solution is to convert x to radians instead of degrees, as the question intended. This will result in an output of 1.
Nano-Passion
1,291
lim as x --> 0 of sin x/x
Embarassingly simple but I'm doing something wrong in the calculation.
x = -.1 f(x)=.017453
x = -.01 f(x)=.017453
x = -.001 f(x)=.017453
x = .001 f(x)=.017453
x = .01 f(x)=.017453
x = .1 f(x)=.017453
I'm supposed to be getting output of digits ---> 1
=/ I plug it in the calculator but its not doing what I want it to do. What am I doing wrong? :blushing:
You are using the wrong units. If x is measured in degrees, then sin(x)/x --> pi/180 = 0.017453 as x --> 0. However, the question intended that x should be in *radians*.
RGV
RGV
Oh silly me, I had it in degree form. :x
Thank you. ^.^
FAQ: Straightforward limit problem =/
What is a straightforward limit problem?
A straightforward limit problem is a mathematical problem that involves finding the value of a limit, which is the value that a function approaches as its input approaches a certain value. In a straightforward limit problem, there are no complicated or unusual techniques required to find the limit, making it a relatively simple problem to solve.
How do you solve a straightforward limit problem?
To solve a straightforward limit problem, you first need to determine the limit expression, which is the function that contains the limit. Then, you can use direct substitution, factoring, or other algebraic techniques to simplify the expression and evaluate the limit. If the limit is undefined, you may need to use L'Hopital's rule or other advanced techniques to find the limit.
Why are straightforward limit problems important?
Straightforward limit problems are important because they allow us to understand the behavior of functions and their graphs near certain points. They also serve as building blocks for more complicated limit problems and are essential for understanding concepts like continuity, differentiability, and the definition of the derivative.
What are some common mistakes when solving straightforward limit problems?
One common mistake when solving straightforward limit problems is forgetting to check for any discontinuities or undefined points in the expression. Another mistake is not simplifying the expression enough before evaluating the limit. It's also important to remember to use proper substitution techniques, such as plugging in the correct value for the limit, and not just the variable itself.
How can I improve my skills in solving straightforward limit problems?
The best way to improve your skills in solving straightforward limit problems is to practice! Make sure you have a solid understanding of algebra and basic limit concepts before attempting more complex problems. You can also seek help from a teacher or tutor, or use online resources and textbooks to learn different techniques and strategies for solving limit problems.
