Strain gage to measure drag in a wind tunnel?
In summary, a strain gage is a device that measures strain in a material by detecting changes in electrical resistance. It is commonly used to measure drag in a wind tunnel, providing accurate measurements for objects of various sizes. However, the accuracy may be affected by factors such as gage quality and wind tunnel stability, and there may be limitations in measuring very small drag forces or in extreme wind conditions. The data collected from a strain gage can be analyzed and compared to theoretical models to interpret the drag forces and make improvements to the object being tested.
gsjbjt
How would a strain gage be set up (on top of the model? around the sting?) to measure drag? I don't quite understand the connection between the force of drag and some sort of compression/tension force...?
Thanks for the clarification.
Consider: what is drag? Where does it come from?
Think of a bending beam...
Related to Strain gage to measure drag in a wind tunnel?
1. What is a strain gage and how does it measure drag in a wind tunnel?
A strain gage is a device that measures the amount of strain, or deformation, in a material. It works by detecting changes in electrical resistance as the material is stretched or compressed. In a wind tunnel, the strain gage is attached to the object being tested and measures the amount of strain caused by the drag force of the moving air.
2. How accurate is a strain gage in measuring drag in a wind tunnel?
The accuracy of a strain gage depends on several factors, including the quality of the gage itself, the stability of the wind tunnel environment, and the skill of the operator. However, with proper calibration and setup, a strain gage can provide highly accurate measurements of drag in a wind tunnel.
3. Can a strain gage be used to measure drag on both small and large objects in a wind tunnel?
Yes, a strain gage can be used to measure drag on objects of various sizes in a wind tunnel. The gage can be customized to fit the specific needs of the object being tested and can provide accurate measurements for both small and large objects.
4. Are there any limitations to using a strain gage to measure drag in a wind tunnel?
While strain gages are a commonly used and reliable method for measuring drag in a wind tunnel, they do have some limitations. For example, they may not be suitable for measuring very small drag forces or in extreme wind conditions. Additionally, the placement and attachment of the gage can affect the accuracy of the measurements.
5. How can strain gage data be analyzed and interpreted in a wind tunnel experiment?
The data collected from a strain gage can be analyzed using various methods, such as graphical analysis and mathematical calculations. This data can then be compared to theoretical models and other experimental results to interpret the drag forces acting on the object in the wind tunnel. Additionally, the data can be used to make improvements and modifications to the object being tested.
  • Aerospace Engineering
  • STEM Academic Advising
  • Mechanics
  • Mechanical Engineering
  • Classical Physics
