Strain Gauge Project Circuit Question
In summary: I suggest that you consult an electronic engineer for more detailed advice.In summary, a circuit must be designed to measure the strain experienced by a stain gauge and to minimize DC common mode voltage. The circuit should use 2 op-amps in tandem for gain of 1000. The circuit should be carefully considered for off set and common mode gain.
kacollie
Design a circuit that uses a stain gauge to create a voltage related to the strain experienced by the gauge. The strain gauge should remain electrically isolated from the ground. The DC common mode voltage should be minimized. Only stain-related signal to be measured does not have any significant energy components with frequencies above 10hz. Random voltage fluctuations unrelated to strain with frequency components above 100hz should be reduced, relative to strain related voltage fluctuations, by a factor of at least 10 without significantly affecting the stain-related voltage measured. Do not use more then 2 op-amps in your circuit. Assume the unloaded resistance of the strain gauge is 120ohms.
This seems really difficult, I would be really impressed if someone had any insight into how to build such a circuit.
I suggest that you have 2 power rails, say +15V & -15V.
Connect a resistor to each rail (equal resistors) and connect the strain gauge between them.
Then connect the ends of the strain gauge to the inputs of a differential amp (use an Op Amp configured as a diff amp).
Use capacitors to limit the bandwidth and design the amp to provide a suitable gain.
eg. a 1 Volt change at the output of the amp would represent a suitable value of strain.
Hey Larry,
Thanks for the prompt response, do you know how I would setup the equations to design such a circuit?
Thanks
I also forgot to put the part about it being amplified by 1000.
Design a circuit that uses a stain gauge to create a voltage related to the strain experienced by the gauge. The strain gauge should remain electrically isolated from the ground. The DC common mode voltage should be minimized. Only stain-related voltage fluctuations caused by the gauge should be amplified by 1000. Assume that the stain-related signal to be measured does not have any significant energy components with frequencies above 10hz. Random voltage fluctuations unrelated to strain with frequency components above 100hz should be reduced, relative to strain related voltage fluctuations, by a factor of at least 10 without significantly affecting the stain-related voltage measured. Do not use more then 2 op-amps in your circuit. Assume the unloaded resistance of the strain gauge is 120ohms.
Have you seen these threads?
https://www.physicsforums.com/showthread.php?t=383720
https://www.physicsforums.com/showthread.php?t=314265
https://www.physicsforums.com/showthread.php?t=230313
I have attached a .pdf that shows a number of Op Amp configurations including a difference amp (page 1).
This should give you a starting point.
There is plently of info available on the internet & electronics forums (eg. www.electro-tech-online.com[/url] & [url]www.edaboard.com[/URL]) that can help you.
You may need 2 Op Amps in tandem for gain of 1000. eg. one (a differential amp) with a gain of say 10 & the other (non differential) with a gain of 100.
You can taper the frequency response in both amps.
You will need to carefully consider off set and common mode gain
  • Op Amp collection.pdf
FAQ: Strain Gauge Project Circuit Question
What is a strain gauge and how does it work?
A strain gauge is a sensor used to measure strain or deformation on an object. It works by converting the mechanical strain or displacement into an electrical signal, which can then be measured by a circuit.
What is the purpose of a strain gauge project circuit?
The purpose of a strain gauge project circuit is to accurately measure and record strain or deformation on an object. This can be useful in various applications such as engineering, structural testing, and material analysis.
How do I choose the right strain gauge for my project?
Choosing the right strain gauge depends on various factors such as the type of material, the expected strain range, and the environment in which it will be used. It is important to carefully consider these factors and consult with experts if needed.
What are some common challenges when working with strain gauge project circuits?
Some common challenges when working with strain gauge project circuits include temperature variations, electrical noise interference, and proper calibration. It is important to address these challenges to ensure accurate and reliable measurements.
Are there any safety precautions I should take when working with strain gauge project circuits?
Yes, it is important to take safety precautions when working with strain gauge project circuits, especially when working with high voltage or sensitive equipment. This includes wearing appropriate protective gear, following proper handling procedures, and ensuring the circuit is properly grounded.
