Can the Strand Tangle Model Unify General Relativity and the Standard Model?
  • A
  • Thread starter physics8553
  • Tags
    Unification
In summary, the article explores the potential of the Strand Tangle Model to unify General Relativity and the Standard Model of particle physics. It discusses how this model, which conceptualizes fundamental particles as strands intertwined in complex tangles, could provide a framework for integrating gravity with quantum mechanics. The paper highlights the challenges of current theories and suggests that the Strand Tangle Model may offer new insights into the fundamental structure of the universe, aiming to bridge the gap between macroscopic and microscopic physical laws.
physics8553
A few publications - as they provide the basis for any discussion. The publications present an approach to derive both the standard model and general relativity from the same fundamental principle. In particular they show that the standard model of particle physics is unique and simple. Experimental predictions are found in the texts.
On the Planck limits as foundations of the strand tangle model:
  • From maximum force to the field equations of general relativity – and implications, International Journal of Modern Physics D 31 (2022) 2242019.
  • From maximum force to physics in 9 lines and towards relativistic quantum gravity, Zeitschrift für Naturforschung A 78 (2022) 145–159.
  • Tests for maximum force and maximum power, Physical Review D 104 (2021) 124079.
  • Comment on "Maximum force and cosmic censorship", Physical Review D 104 (2021) 068501.
On the standard model deduced from strand tangles:
  • On the relation between the three Reidemeister moves and the three gauge groups, International Journal of Geometric Methods in Modern Physics (2023).
  • Testing a conjecture on quantum chromodynamics, International Journal of Geometric Methods in Modern Physics, 20 (2023) 2350095.
  • Testing a conjecture on quantum electrodynamics, Journal of Geometry and Physics 178 (2022) 104551.
  • Testing a conjecture on the origin of the standard model, European Physical Journal Plus 136 (2021) 79.
  • A conjecture on deducing general relativity and the standard model with its fundamental constants from rational tangles of strands, Physics of Particles and Nuclei 50 (2019) 259–299.
On general relativity deduced from strand tangles:
  • Testing a microscopic model for black holes deduced from maximum force, chapter in the book „A Guide to Black Holes“, Nova Science Publishers (2023).
  • Testing a conjecture on the origin of space, gravity and mass, Indian Journal of Physics 96 (2022) 3047–3064.
With the exception of Physical Review D (82 percentile) all of those journals consistently publish borderline or low quality articles, based on Eigenfactor article impact ratings.
J Geom Phys, 60 percentile
Int J Geom Methods M, 54 percentile
Int J Mod Phys D, 49 percentile
Eur Phys J Plus, 40 percentile
Phys Part Nuclei, 21 percentile
Z Naturforsch A, 14 percentile
Indian J Phys, 12 percentile
Likes phinds and berkeman
In science, a theory is tested by comparing its statements and its predictions with experiments.
The strand tangle model is built on a single fundamental principle, based on an idea by Dirac: Every process and every system in nature is due to fluctuating strands of Planck radius, for which each change from an overpass to an underpass yields Planck's quantum of action ℏ.
The strand tangle model states: The fundamental principle yields quantum theory and the standard model, with its wave functions, particle content, gauge interactions and unique fundamental constants (particle
masses, coupling strengths and mixing angles), yields general relativity and yields three dimensions of space.
The strand tangle model predicts: The fundamental principle allows precise calculations of the fundamental constants that will yield the observed values. The principle implies that no physics beyond the standard model and beyond general relativity will be discovered. The fundamental principle further predicts that no inequivalent model will achieve these results.
As required in science, all these statements and predictions can be tested. In fact, they are already being tested. In addition, any new good test and any new good counterargument - positive, negative, correct or wrong - is rewarded with an invitation to dinner.
  • Skeptical
Likes weirdoguy
And PF already had a long thread about this that was ultimately closed to further replies: https://www.physicsforums.com/threa...d-physics-of-particles-nuclei-50-2019.973097/
Likes Dale
Well. You billed the papers as the basis for a “discussion” but then gave a completely non-responsive reply to a substantive criticism of the low quality of the above references. So this seems more like an advertisement of these newer low-quality publications. Advertisements do not require replies, so with that we will close the thread.
weirdoguy said:
I guess nothing has changed dramatically since then. Which is a good summary of this "theory".
Indeed.
Likes Vanadium 50 and topsquark
FAQ: Can the Strand Tangle Model Unify General Relativity and the Standard Model?
What is the Strand Tangle Model?
The Strand Tangle Model is a theoretical framework that attempts to describe the fundamental particles and forces of nature using the concept of tangles in three-dimensional space. It proposes that all particles and interactions can be represented by different configurations of tangled strands, aiming to provide a unified description of both quantum mechanics and general relativity.
How does the Strand Tangle Model aim to unify General Relativity and the Standard Model?
The model seeks to unify General Relativity and the Standard Model by representing both gravitational and quantum phenomena through the same underlying structures—tangled strands. By doing so, it aims to provide a single, coherent description of all fundamental forces and particles, potentially resolving inconsistencies between quantum mechanics and general relativity.
What are the key components of the Strand Tangle Model?
The key components of the Strand Tangle Model include strands, which are hypothetical one-dimensional objects, and their tangles, which represent particles and interactions. The model also incorporates rules for how these strands can tangle and untangle, which correspond to physical processes and conservation laws observed in nature.
Has the Strand Tangle Model made any testable predictions?
As of now, the Strand Tangle Model is still largely theoretical and has not yet made specific, testable predictions that have been experimentally verified. However, proponents of the model are working on deriving predictions that could be tested in future experiments, particularly in high-energy physics and cosmology.
What are the main criticisms of the Strand Tangle Model?
The main criticisms of the Strand Tangle Model include its lack of empirical evidence and the speculative nature of its foundational concepts. Critics argue that the model is not yet sufficiently developed to provide concrete predictions or to be rigorously tested against experimental data. Additionally, some physicists are skeptical about whether the model can truly reconcile the differences between quantum mechanics and general relativity.
