Strange behaviour of roulette ball falling
In summary, the speaker has analyzed roulette spins using Sony Vegas and found that the time it takes for the ball to complete a turn may affect its velocity and therefore its time to fall off the rim. However, upon further analysis, the speaker has found inconsistencies in the results and doubts that there is any nonlinear relationship or function involved. They have also considered physical factors such as initial velocity, wear and tear of the system, and external conditions as potential influences on the outcome. There is also a possibility for artificial manipulation of the outcome. The speaker wonders if the roulette wheel being used is rigged for better odds for the house.
borson
30
I have analysed some roulette spins with sony vegas in order to get the time for each turn of the ball.
It is supposed that if the time that takes for the ball to complete a turn is higher, it means that its velocity is faster and thus the time at which it will fall off from the rim will be lower too.
For instance, let's say that the ball completes a turn in 0,5 seconds. Thus, it is supposed to be faster than when the ball completes the turn in 0,6s. Hence, the former is supposed to last more time in falling into the wheel than the 2nd. For instance, the 1st should last.. let's say.. 22s. and the 2nd 20s. That would be the normal.
However in the spins that I have analyzed (from several roulettes) I always get weird results.
Some "turn-times" are lower than others, and their final times are also lower than those of the other lower turn times. I mean, it is like if the time turn of 0.6s lasted more time in falling than the turn-time of 0.5s. Which wouldn't make sense.
Due to this and other strange things (some "turn-times" which are quite different, have the same or similar final times) I do not see that there is any nonlinear relationship or that it follows any kind of function.
I have been reading on internet some papers and articles and, it seems that if there is any kind of inclination, no matter how small that angle is, there are zones of the roulette in which the ball will fall and it would lead to biases. I do not know if it could be related to the outcomes that I have obtained.
What do you think?
Thank you all for your help!
I am not a roulette expert and not a gambler but as I see it, there are various physical factors that influence the outcome like the initial velocity vector on the ball, how much worn out are the various components of the system, temperature, humidity, moisture just to name a few. Now, in order to attempt to calculate precisely the whole motion of the ball during one "spin" you have to know every and each one of these factors precisely, which obviously can't be done. Also, it is highly unlikely that any two throws in a row can start identically i.e. with the exact same velocity. All these give - at least on average, a different bias each time. Even a dexterous croupier can throw a ball directed to a certain "field" of the disk but this is subject to some uncertainty and cannot be done for a specific point i.e. number..
On the other hand the whole thing can be controlled through artificial factors (like an electromagnet) that can give a "shot" at a particular instant and pull the ball prematurely. I don't really now if this happens but it could, at least in principle.
Are you sure that the wheel that you are using is not riged for better odds on the house's side?? hehe
FAQ: Strange behaviour of roulette ball falling
What causes the roulette ball to fall in a seemingly random pattern?
The strange behavior of the roulette ball falling is due to the laws of physics and the design of the roulette wheel. The ball is spun in the opposite direction of the wheel, causing it to bounce and hit the sides of the wheel, resulting in an unpredictable landing spot.
Can the behavior of the roulette ball be predicted or controlled?
While some people claim to have strategies for predicting the behavior of the roulette ball, it is ultimately a game of chance and the outcome cannot be controlled or predicted with 100% accuracy. The unpredictable nature of the ball's movement is what makes roulette a game of luck.
Are there any patterns or biases in the way the roulette ball falls?
There have been studies and observations that suggest certain numbers or sections of the roulette wheel may have a higher likelihood of the ball landing on them. However, these are just theories and the randomness of the ball's movement makes it impossible to determine any true patterns or biases.
Is the speed of the roulette ball falling a factor in the outcome?
The speed at which the roulette ball falls is a crucial factor in the game. The faster the ball is spinning, the more unpredictable its movement will be. This is why casinos have strict regulations on how fast the dealer must spin the wheel to ensure fairness in the game.
What factors can affect the behavior of the roulette ball falling?
Aside from the speed of the ball, other factors that can influence its behavior include the condition of the wheel, the surface it is spinning on, and external forces such as air currents. These factors can all contribute to the unpredictability of the ball's movement and make it impossible to accurately predict its outcome.
