Strange claims about heat transfer
In summary, the company's argument is that their in-slab heating element is more efficient than resistive cable elements, but this claim is not supported by evidence.
meeotch1
I'm trying to evaluate floor heating systems for installation in my new studio, and I have to admit that my thermodynamics is a bit rusty... But I came across the following, and I could use a sanity-check.
Basically, it's an in-slab heating element that claims to be 2.5x "more efficient" (and thus cheaper to run) than the resistive cable type elements that are widely used. http://www.warmfloor.com/en-us/floor-heating-advantages/radiant-floor-heating-with-a-flat-heater-is-more-efficient. The page will spit a pdf at you, but don't freak out. http://www.warmfloor.com/images/stories/pdf/efficiency/Efficiency_(Imperial).pdf
Q1: I understand that more surface area would lead to a more efficient & even transfer of heat to the slab. But iirc, resistive conversion of electricity to heat is nearly 100% efficent, and since the element is completely contained, there's nowhere else for the heat to go but into the slab. So if your building is losing X heat per hour to the environment, you'll end up putting X heat / hour back into maintain a given temp. How could an element of one kind or another make any difference?
Q2: More generally, afaik the point of radiant heating is that it doesn't "waste" energy heating the air, but instead radiates it directly to objects (e.g. people) in the room, allowing you to have lower interior temps. But for a slab-on-grade building, I'd think the higher temp differential between the slab and the Earth would mean greater energy loss through the slab, negating the savings - no? (The pdf above weirdly doesn't even mention radiant transfer.)
Please don't let the clumsy advertising copy on that webpage bias you, I'm genuinely interested in the physics behind this. (The company in question has been around for like 30 years, and has a 30,000sf factory entirely heated by their own system, so I don't doubt it's as good as any other in-slab solution. Just possibly not better.)
Science news on Phys.org
Welcome to PF!
Your knowledge/instinct is correct: This is BS. In my own words:
1. An electric resistance heater is always exactly 100% efficient.
2. A radiant floor should be well insulated, so all heaters should perform about the same: they should send about the same amount of heat into the room and waste the same amount of heat dissipated below the slab.
3. A gas boiler is 80-97% efficient, but who cares that it is below 100% if the energy costs 1/5 what electricity costs?
The only place where you might be a little wrong (but only a very little) is in part of #2. Delivering heat directly to your feet means that you can feel warmer when the room is cooler, so you save energy versus a system that heats the air directly. But this benefit applies to all radiant floor heating systems, not just to this specific one. The only potential pitfall (as you say) is you are also delivering some of the heat directly to the ground and lowing it. So in order to really be as efficient overall as forced-air, you need good insulation between floor and slab.
BTW, is clumsy advertising copy any more effective if printed in a 30 year old brochure vs printed on a website? Do you really think good engineering sells products better than good advertising? Please note, I am an engineer and I'm still asking the question...
What the company's claim is, is that more finely spaced heating elements in the slab can run at a lower temperature, to obtain the same amount of heating into the room as more coarsely laid heating elements, due to less heat loss going into the ground below as a result of the lower temperature with the finer spaced elements.
Is it 2.5 times as efficient? That would depend upon the insulation laid under the slab. For a poorly insulated slab, it could be. For a reasonably insulated slab, the savings from less heat loss should not be as great.
Hey guys - thanks for the responses. In thinking a bit about their "downward transmission" argument, it still doesn't sit 100% comfortably with me. The pdf seems to argue that the heated area is wider for their element, giving faster transmission to the air in the room. Surely this argument applies for transmission to the (lower) slab as well, though? Smaller area (cable) -> slower transmission to air -> higher temp needed, but smaller area -> slower transmission to sub-slab, and it all cancels out, since the terms are all linear. (Well, actually an integral across the area, with the cable-heated area having a hotter core and cooler edges, but I'm not going to try and figure that out.)
I should say that there are other things I like about this system: it's wired in parallel, unlike cable systems, and you can cut or drill through the elements without knocking out the whole system. But it is more expensive, and requires several large 240-24VAC step-down transformers.
w.r.t. radiant floor systems in general: as I understand it, the big win is that heat is radiated/transmitted directly to objects (you, and your feet), allowing you to lower the air temp and achieve the same subjective "warmness". Though I'd think that having a heated slab actually counteracts this to some extent, since concrete is a worse insulator even than glass, and certainly than a well insulated ceiling.
I would approach this question by first looking at the claims made by the company and evaluating them based on established scientific principles. Let's address each of your questions separately.
Q1: You are correct in stating that resistive conversion of electricity to heat is nearly 100% efficient. This means that regardless of the type of element used, the heat output will be the same. However, the efficiency of a heating system is not just determined by the heat output, but also by the energy input. In this case, the efficiency is being compared between an in-slab heating element and a resistive cable type element. The in-slab heating element uses a larger surface area to transfer heat to the slab, which means it requires less energy input to achieve the same heat output as the resistive cable type element. This is what is meant by "more efficient" in this context.
Q2: You are correct in stating that the point of radiant heating is to directly heat objects in the room, rather than the air. However, in the case of a slab-on-grade building, the slab itself is the object being heated. The difference in temperature between the slab and the Earth does not necessarily mean greater energy loss through the slab. In fact, the larger surface area of the in-slab heating element may actually result in a more even distribution of heat, reducing energy loss through the slab.
In summary, while the language used on the company's website may be misleading, the claims about the efficiency of their in-slab heating system are based on sound scientific principles. It is important to carefully evaluate all claims and consider the underlying physics before making any decisions about which heating system to install.
Related to Strange claims about heat transfer
1. What is the most common strange claim about heat transfer?
The most common strange claim about heat transfer is the idea that certain objects or materials have the ability to transfer heat without any temperature difference, also known as "cold transfer." This claim goes against the fundamental laws of thermodynamics, which state that heat always flows from a warmer object to a cooler object.
2. Can heat be transferred through a vacuum?
Yes, heat can be transferred through a vacuum via radiation. Radiation is a form of heat transfer that does not require a medium, and can travel through a vacuum at the speed of light.
3. Is it true that some materials can "trap" heat?
While some materials may have better insulating properties than others, no material has the ability to completely trap heat. Heat will always flow from a warmer object to a cooler object, and eventually reach a state of equilibrium.
4. Are there devices that can produce more heat than the energy put into it?
No, this goes against the law of conservation of energy. Heat can be converted from one form to another, but it cannot be created or destroyed. Any device claiming to produce more heat than the energy put into it is likely using deceptive methods or not taking into account all forms of energy input.
5. Can heat transfer occur instantaneously?
No, heat transfer always takes time. The rate at which heat is transferred depends on factors such as the temperature difference, the surface area, and the type of material. While some materials may transfer heat more quickly than others, it is never instantaneous.
  • Mechanical Engineering
  • Thermodynamics
  • Electrical Engineering
21K
  • Thermodynamics
