Strange l'Hospital's Rule with ln
  • Thread starter Thread starter phillyolly
    Ln Strange
The limit of (lnx)^2/x as x approaches infinity is an indeterminate form of ∞/∞, allowing the application of L'Hôpital's Rule. After differentiating, the expression simplifies to (2 ln x)/x. Further application of L'Hôpital's Rule leads to the limit of (2/x) as x approaches infinity. This results in a final answer of 0, confirming that the original limit converges to zero. The discussion emphasizes the importance of recognizing indeterminate forms and applying L'Hôpital's Rule effectively.
phillyolly
lim(x→∞)(lnx)^2/x
Since lim(x→∞)(lnx )^2=∞ and lim(x→∞)x=∞, the function is indeterminate, ∞/∞.
lim(x→∞)(lnx)^2/x=lim(x→∞) d/dx (lnx )^2/(d/dx x)=lim(x→∞)(2 lnx (1/x))/1
An I am stuck...
phillyolly said:
lim(x→∞)(lnx)^2/x
An I am stuck...
I think L'Hostpital's rule can be used very easily here. - just apply it again.
Alternatively, it's not hard to see the answer from the following expansion of logarithm.
{\rm ln}(x)=2\sum_{i=1}^\infty {{1}\over{2i-1}}\Bigl({{x-1}\over{x+1}}\Bigr)^{2i-1}
With experience, you will recognize the answer to similar limits by inspection. Not many functions increase monotonically as slowly as logarithm. Granted, that's not a reliable, nor mathematically correct way to get the answer, but it helps to know the answer before you solve the problem.
This might be a higher-level answer. My answer should be looking much easier cause we don't work with i's and sums.
OK, don't worry about that. Just take your first answer from L'Hospital's rule and put it in a simple numerator over denominator form. Then apply the rule again.
(2 lnx (1/x))/1 = 2(ln x)/x
Can you finish it from there?
Okay, so here it is:
lim(x→∞) (2 lnx)/x=
lim(x→∞)(d/dx lnx)/(d/dx x)=
lim(x→∞)(2 (1/x))/1=
lim(x→∞)(2/x)
Should I take a derivative again, or it's enough and 2/infinity equals zero?
You have it, the answer is 0. You can't use l'Hopital's rule again anyway since 2/x isn't indeterminate like the other expressions you had before.
I see it now, thank you very much.
9K
  • · Replies 19 ·
