- 9,630
- 10,639
I was zooming around the NE region of the South Island of New Zealand in Google Earth today and discovered a classic example of offset stream channels across a major fault, the Awatere Fault.
The Awatere Fault which is one of the major faults that the Alpine fault splinters into in the upper South Island. It's companions are the Wairau Fault -- the direct continuation of the Alpine Fault; The Clarence Fault and the Hope Fault. These 4 major faults all run parallel to each other and between them release the tectonic stresses that build up along this section of the Australian and Pacific plate boundary.
The image below shows offsets of streams and ridgelines
The yellow arrows clearly mark the direction of the fault trace
Two obvious ridge offsets are marked A--A and B--B
The upper side B ends in a steep bank at the fault trace.
1, 2, 3 lines mark a stream offset from the blue line on the upper side of the trace.
I suspect some of the other stream channels to the left of the # 1, are quite possibly even earlier offsets
For anyone interested in looking at the bigger/clearer image in Google earth. The coordinates are
41.779398 S 173.785685 EDave
