Strength of materials question
Also, I am not sure if my description of the process is clear, so let me know if you need more explanation.In summary, a rigid steel plate is supported by three posts of high-strength concrete, with the middle post being shorter than the others by 1.0 mm. The maximum allowable load Pallow is determined by calculating the total load capacity of the two outer columns (F1) and the additional load capacity of all three columns (F2), which is equally shared due to the assumption of a rigid plate. The total allowable load is found to be 1560 kN or 1.56 MN.
kieranl
24
A rigid steel plate is supported by three posts of high-strength concrete each having an effective cross-sectional area A =40000 mm2 and length L = 2 m. Before the load P is applied, the middle post is shorter than the others by an amount s = 1.0 mm.
Determine the maximum allowable load Pallow if the allowable compressive stress in the concrete is σallow = 18 MPa. (Use E = 30 GPa for concrete.)
Working as well as diagram are shown in the pdf attached. Just looking for feedback on how I completed the question as it just seemed a little to easy for an assignment question?? cheers
  • Document1.pdf
Yes, not that easy. The middle column doesn't take nearly as much load as the outer ones, which have taken up most of the load before the middle column sees any load at all. The load is equally shared amongst the three only after the first 1 mm of deflection in the outer ones.
To start with, I do not feel that the assumption of a "rigid" steel plate is realistic. In structural analysis, everything deforms under load, and that is the basis of inderterminate structures like this present one.
However, since no physical information is available for the steel plate, we will have to live with the assumption of the plate being rigid.
The loading of the three columns progresses in two stages, with respective load capacities of F1 and F2.
F1 represents the total force required to deform the two outer columns to a deformation of 1 mm, as you have correctly calculated.
F2 represents the additional load shared by all three columns until one or more columns bust under σallow = 18 MPa. It is obvious that F2 is equally shared by all three columns because of the "rigid" assumption, and therefore the additional stress capacity of
σ = 18 MPa - 15 MPa = 3 Mpa.
If you do the detailed calculations, you will find that F1+F2 = 1.56 Mpa.
Post your calculations if you need more details.
Hi mathmate, following your logic (which seems very reasonable), I get F1 = 1200kN and F2 = 120kN, therefore F1 + F2 = 1320kN
I can't seem to convert this to 1.56MPa to verify my answer.. could you please help?
Thank you ;)
Sorry, I have slipped the wrong unit. I meant 1.56 MN, or in your notation, 1560 kN.
The way I looked at it, when the two outer columns were supporting the load,the total load that creaed the 1 mm shortening is:
0.04 m2 * 2 columns * 15 Mpa = 1200 kN.
After the middle column is engaged, the outer columns have a remaining capacity of 3 Mpa before failure, so the additional load would be:
0.04 m2 * 3 columns * 3 Mpa = 360 kN.
Let me know if I slipped somewhere in my calculations, which tends to happen if I need to use the calculator.
FAQ: Strength of materials question
What is the concept of "strength of materials"?
The strength of materials is a branch of mechanics that studies the behavior of solid objects when subjected to external forces. This includes understanding how materials deform, break, and withstand different types of loads.
What are the different types of loading that can affect the strength of a material?
There are four main types of loading that can affect the strength of a material: tension, compression, shear, and bending. Tension is when a material is pulled apart, compression is when it is pushed together, shear is when it is cut or twisted, and bending is when it is subjected to a combination of tension and compression.
How is the strength of a material measured?
The strength of a material is typically measured using stress and strain. Stress is the amount of force per unit area applied to a material, while strain is the resulting deformation of the material. The relationship between stress and strain can help determine the strength and stiffness of a material.
What factors can affect the strength of a material?
The strength of a material can be influenced by various factors, such as its composition, microstructure, and manufacturing process. Other factors include temperature, loading rate, and the presence of defects or imperfections in the material.
Why is understanding the strength of materials important in engineering and design?
Understanding the strength of materials is crucial in engineering and design as it allows for the selection of appropriate materials for a given application. It also helps in predicting how a material will behave under different loading conditions, ensuring the safety and reliability of structures and products.
