Strength of Square Steel Tubing
In summary, a high school student is asking for help with calculations for a bike design. The most common type of structural tubing is made from carbon steel with a maximum yield stress of 36,000 psi. The student should check with steel suppliers for stronger grades. The student will need a book on mechanics of materials and a few good free body diagrams to find the forces acting on the bike frame.
Windsor EDD
Hi I'm a high school student and need help with the calculations for a bike design. I am required for the design to use 1.5" mild steel square tubing at 1/16" thick for it. I need to know what the strength of the tubing is before i can make or tweak the design. Can anyone help with my predicament?
The most common (and probably cheapest) square structural tubing is made from A36 carbon steel with a maximum yield stress of 36,000 psi.
There may be stronger grades, but you should probably check with (or google) steel suppliers.
Additional info and clarification:
A36 steel has a minimum yield stress of 36000 psi
Your design should have a safety factor so that maximum tensile stress in bending is less than 21,600 psi (same for axial loading)
Max shear stress should be kept below 14,400 psi.
Thanks, also to find the strength of the tubing I'd multiply the area of the tube by the Maximum Yield Stress right? Or would there be some other geometry that would affect the outcome?
It's a little more complicated than that. If your tube is purely in tension or compression due to a load applied axially, then the stress = applied force / area of the tube. Note that the area of the tube is not 1.5 x 1.5, but the area of the metal only.
If your tube has a bending moment or a twisting moment applied, then different formulas will apply. Also, combining several tubes to make a frame work requires special analysis to determine stress.
What you need is a good simple mechanics of materials or strength of materials book, but it is hard to pick out 'just" what you need (which is all about beams) to find the answer without working through a bunch of material.
if you can find a copy of "Strength and Stiffness of Engineering Systems" by Leckie and Bello and published by Springer in 2009 -the e-ISBN # is 978-0-387-49474-6 - Chapter 6 will be of great interest to you.
You will also need a few good free body diagrams to find the forces acting on each portion of the bike frame.
It's interesting stuff, just stay focused on each part till you get to the next one. A good book on the design process is "The Mechanical Design Process" by Ullman. This is a cool project. Lots to learn! :)
These are just some Mechanics//Strength of Materials resources that may be of help for this or similar problems:
The MIT MofM course in Opencourseware: http://ocw.mit.edu/courses/material...11-mechanics-of-materials-fall-1999/index.htm
Engineer's Edge calculators: http://www.engineersedge.com/mechanics_material_menu.shtml
Videos: http://sbainvent.com/strength_of_materials/#.UMqa2-TWLvk
Some good discussion from a while back @ homebuiltairplanes: http://www.homebuiltairplanes.com/forums/aircraft-design-aerodynamics-new-technology/3372-round-vs-square-tube-strength.html
and here: http://answers.google.com/answers/threadview/id/523190.html
Thank you I will be sure to check that out, and I like this project a lot because I learn new things everyday. Also do you by any chance know if it is possible to get triangular tubing for the bike or is that not a good idea?
The strongest tube will have a round cross-section. I have never seen triangular steel tube offered for sale. A triangular cross section would be very expensive to produce and mechanically inferior to a square tube.
For more information about what is available you might look at some of the online metals sellers like
www.speedymetals.com
www.metalsupermarkets.com
and my personal favorite: http://www.aircraftspruce.com/menus/me/index.html
and since weight is important to bicycle designers as well as aircraft designers:
http://exp-aircraft.com/library/heintz/material.html
Related to Strength of Square Steel Tubing
What is the strength of square steel tubing?
The strength of square steel tubing is determined by its structural properties, which include its material composition, dimensions, and manufacturing process.
How is the strength of square steel tubing measured?
The strength of square steel tubing is typically measured using the yield strength and ultimate tensile strength. Yield strength is the maximum amount of stress the tubing can withstand before it begins to deform permanently, while ultimate tensile strength is the maximum amount of stress it can withstand before breaking.
What factors affect the strength of square steel tubing?
The strength of square steel tubing can be affected by several factors, including the type and grade of steel used, the dimensions and thickness of the tubing, and the manufacturing process used to create it. Additionally, environmental factors such as temperature and corrosion can also impact the strength of the tubing.
How does the strength of square steel tubing compare to other types of tubing?
The strength of square steel tubing is typically higher than that of round or rectangular tubing of the same material and dimensions. This is because the square shape provides more structural support and reduces the risk of buckling. However, the strength of square steel tubing may be lower than that of other materials such as aluminum or titanium.
What are the common applications of square steel tubing?
Square steel tubing is commonly used in the construction industry for structural support, as well as in the automotive and aerospace industries for its strength and durability. It is also used in the manufacturing of furniture, appliances, and other consumer goods.
  • Mechanical Engineering
10K
