Stress and Strain, load and extension
In summary, a stress vs. strain graph for a material will generally have the same shape as its load vs. extension graph, with the same important points such as UTS corresponding to the same thing. The stress-strain and load-extension graphs for different materials, such as metal wire, steel spring, rubber band, and polyethene strip, will have similar main points such as limit of proportionality, elastic limit, upper yield point, lower yield point, UTS, and breaking point, but they may occur at different points on the graph due to changes in cross sectional area and material properties.
Big-Daddy
343
Firstly, does a stress vs. strain graph for a material always take the same general shape as its load vs. extension graph (with the same important points, e.g. UTS, having the same shape and corresponding to the same thing)?
Secondly, what do the stress-strain and load-extension graphs look like for a metal wire, steel spring, rubber band and polyethene strip, and do these graphs all have all of the main points (i.e. limit of proportionality, elastic limit, upper yield point, lower yield point, UTS and breaking point) at separate points in the graph?
stress = force/area so as long as the cross sectional area does not change (which it does !) then a graph of force against extension is essentially the same as stress against strain.
Strain = extension/original length so a graph of stress against strain should be the same (essentially) as a graph of force against strain
Related to Stress and Strain, load and extension
1. What is the difference between stress and strain?
Stress refers to the force applied to a material, while strain refers to the deformation or change in shape of the material due to that force.
2. What are some common causes of stress and strain?
Stress and strain can be caused by various factors such as weight, pressure, tension, compression, and bending. They can also be caused by external forces like temperature changes or chemical reactions.
3. How are stress and strain measured?
Stress is typically measured in units of force per unit area, such as pounds per square inch (psi) or newtons per square meter (N/m^2). Strain is measured as a dimensionless quantity, typically expressed as a percentage or decimal.
4. What is the relationship between load and extension?
Load and extension are directly proportional to each other, meaning that as the load or force applied to a material increases, the extension or deformation of the material also increases. This relationship is known as Hooke's Law.
5. How do engineers use stress and strain data in their designs?
Engineers use stress and strain data to determine the strength and durability of materials when designing structures and products. This data helps them select the appropriate materials and dimensions to ensure the safety and functionality of their designs.
  • Mechanical Engineering
25K
  • General Engineering
11K
